Вроде памяти не хватает. Оптимизируй сцену. Начни отсюда : render> run render diagnostics
Теперь зайди в script editor и почитай диагноз
file -f -new;
// Warning: Active stereo does not work with Aero enabled. Active stereo has been disabled. //
// untitled //
commandPort -securityWarning -name commandportDefault;
// Error: Could not open command port commandportDefault because that name is in use. //
// mental ray for Maya 2012
// mental ray for Maya: setup
// mental ray for Maya: initialize
// mental ray for Maya: using 1 license
// mental ray for Maya: register extensions
// mental ray Node Factory: loaded
// mental ray for Maya: successfully registered
// parsing C:/Program Files/Autodesk/Maya2012/mentalray/include/AdskShaderSDKWrappers.mi
// generating Maya nodes...
// parsing C:/Program Files/Autodesk/Maya2012/mentalray/include/architectural.mi
// loading C:/Program Files/Autodesk/Maya2012/mentalray/lib/architectural.dll
// parsing C:/Program Files/Autodesk/Maya2012/mentalray/include/base.mi
// loading C:/Program Files/Autodesk/Maya2012/mentalray/lib/base.dll
// parsing C:/Program Files/Autodesk/Maya2012/mentalray/include/contour.mi
// loading C:/Program Files/Autodesk/Maya2012/mentalray/lib/contour.dll
// parsing C:/Program Files/Autodesk/Maya2012/mentalray/include/paint.mi
// loading C:/Program Files/Autodesk/Maya2012/mentalray/lib/paint.dll
// parsing C:/Program Files/Autodesk/Maya2012/mentalray/include/physics.mi
// loading C:/Program Files/Autodesk/Maya2012/mentalray/lib/physics.dll
// parsing C:/Program Files/Autodesk/Maya2012/mentalray/include/production.mi
// loading C:/Program Files/Autodesk/Maya2012/mentalray/lib/production.dll
// parsing C:/Program Files/Autodesk/Maya2012/mentalray/include/subsurface.mi
// loading C:/Program Files/Autodesk/Maya2012/mentalray/lib/subsurface.dll
// parsing C:/Program Files/Autodesk/Maya2012/mentalray/include/surfaceSampler.mi
// loading C:/Program Files/Autodesk/Maya2012/mentalray/lib/surfaceSampler.dll
updateRendererUI;
file -f -options "v=0" -typ "mayaBinary" -o "C:/Documents/maya/projects/default/scenes/House 2.mb";addRecentFile("C:/Documents/maya/projects/default/scenes/House 2.mb", "mayaBinary");
requires "Mayatomr" "2012.0m - 3.9.1.36 ";
requires "stereoCamera" "10.0";
// File read in 4 seconds.
// Warning: Can't perform polySplit31 on selection //
// Warning: Could not find an appropriate startup camera: front. A substitute will be used. //
select -r pPlane3 ;
displaySmoothness -divisionsU 0 -divisionsV 0 -pointsWire 4 -pointsShaded 1 -polygonObject 1;
subdivDisplaySmoothness -smoothness 1;
displaySmoothness -divisionsU 3 -divisionsV 3 -pointsWire 16 -pointsShaded 4 -polygonObject 3;
subdivDisplaySmoothness -smoothness 3;
select -r pPlane3.vtx[0:402] ;
doDelete;
// Warning: Some selected vertices have complex edge attachment; Delete Edge/Vertex removes selected vertices and related edges //
// Undo: doDelete
select -r pPlane3.f[0:389] ;
doDelete;
file -save;
// C:/Documents/maya/projects/default/scenes/House 2.mb //
hilite -r pPlane2 ;
hilite -u pPlane2 ;
select -r pPlane2 ;
select -cl ;
MENTAL RAY RENDER DIAGNOSTICS:
// 0 warning
Как только нажимаю рендер с ментал рей, то прога думает думает и тупо закрывается с открытым окном де написано mental ray for Maya 2012
mental ray: version 3.9.1.36, Feb 2 2011, revision 138829
initMPS with licenseOption 0
mental ray: got 8 satellite CPUs.
mental ray: out of memory
MEM 0.0 fatal 031008: can't allocate 1222356 bytes.
Даже при самом самом низком разрешении выкидывает(
