Fusion 9 стал доступен для скачивания!
Blackmagic Fusion 9.0
• New VR tools & features
• New file format support, including Apple ProRes
• New keying tools and improvements
• OpenCL acceleration of many tools
• Improved script support for UI toolkits, memory handling, and more
• Many new additions and tweaks
• General performance and stability improvements
Blackmagic Fusion Studio 9.0
• New Bins playback system
• New Planar and Camera trackers
Details for 9.0
New VR tools
• Lag free, 90 fps smooth viewing of 360° images and 3D scenes.
• Support for both Oculus Rift and HTC Vive headsets.
• 360° image viewer allows rotating the viewpoint of latlongs & cubemaps (same controls as rotating the 3D viewpoint)
• The Texture tool will now use red-green channels as a UV map, if UV channels aren’t found, for easier stitch mapping.
• Spherical Camera - renders 360° captures of 3D scenes as a cubemap or latlong/equirectangular image.
• PanoMap - converts between latlong/equirectangular and various cubemap image formats, and also allows spherical rotation.
• LatLong Patcher - extracts an undistorted 90° window from a latlong image for paint fixes etc, and applies distortion to map fixes or new elements back into latlong images.
• Spherical Stabilizer - smooths and stabilizes camera rotation in 360° clips. (Fusion Studio required)
Formats
• Fusion is now certified for Apple ProRes on all three platforms. The unsupported 32bit QuickTime framework is no longer used on Windows.
⁃ Fusion Studio can load and save Apple ProRes on all platforms.
⁃ Fusion (free) can load and save Apple ProRes on macOS.
⁃ Fusion (free) can load but not save Apple ProRes on Windows and Linux.
⁃ Render Node can load but not save Apple ProRes on all platforms.
• H.264 support on macOS and Windows.
• MXF file support.
• Improved DNxHD support.
• FFmpeg can be installed to further increase codec support.
Tracking
• Camera Tracker will track and matchmove live action camera’s motion and reconstruct the identical movement and motion paths into Fusion’s 3D environment. (Fusion Studio required)
• Planar Tracker tracks subjects and regions in a live action scene and calculates planes of motion. It tracks perspective, positions, scale, and rotation. Corner pinning a new billboard image onto a moving shot or a new sign on the side of a truck is an example. (Fusion Studio required)
• Planar Transform for Roto will output a Planar Transform node which is used to control roto shapes. (Fusion Studio required)
• Point Cloud has updated features.
Keyers
New channel difference Delta Keyer and Clean Plate tools as well as updates to Ultra keyer.
• Delta Keyer
- A classic channel difference keyer, with color bias and spill replacement.
- Supply a clean plate to improve shadows and separation from background (a background colour still needs to be selected to indicate the dominant background channel).
• Ultra Keyer
- Improvements allow a wider range of background colours (not limited to fully saturated blue and green).
- Separate solid and transparent garbage masks.
- Can use background subtraction rather than post-multiply to remove the screen.
• Clean Plate
Build a clean plate for DeltaKeyer when a proper clean plate isn’t available.
И еще много чего интересного в этом мощном релизе!!!
Details for 9.0
New VR tools
Formats
• MXF file support.
Tracking
Keyers
• Delta Keyer
• Ultra Keyer
• Clean Plate
