Вышла бета Turtle 3
Тема в разделе "Turtle", создана пользователем Пётр Вишняков, 1 мар 2006.
Модераторы: Moderator.
  1. Пётр Вишняков
    Пётр Вишняков Пользователь сайта
    Bug fixes:
    Fixed bug in external batch rendering.
    Fixed bug in Illumination pass and color bleeding.
    Fixed crash bug with occlusion obeying transparency.
    Made the prepass to be executed only once per renderlayer rather than
    once per renderpass.
    Fixed command line region rendering.
    Removed unnecessary output for when the license server could not be
    found during normal maya work.
    Fixed problem when connecting blend shape attributes to shaders.
    Made the bake layer system more reliable.
    Fixed problem when using FG and surface transfer.
    Removed prepass layers in exr-files.
    Fixed crash bug when doing Final Gather pass and normal pass in
    surface transfer.
    Ptm reader bug fix.
    Fixed adaptive tile size when using dof.
    Made the frame numbering more like maya.
    Fixed problem with 256x256 tile size in texture cache.
    Fixed bug with Default Color on all 2d textures.
    PTM GI fix, use PTM color instead of constant color for photons.
    Fixed iff writing with depth pass.
    Fixed crash bug on mac.
    Improvements:
    Support for saving textures to the render view.
    Early out optimization in displacement mapping!
    Support for mirrored uv-layouts.
    Disabled file writing when doing region baking.
    Abort responsiveness improvements and more progress bars.
    Added occlusion ray shooting to LUA.
    Updated FG filter to depend less on scene scale
    Added Multithreading and raytracing support to LUA.
    Added project-relative path support for LUA node.
    OpenExr layer selection in the file texture and ptm file node.
    Added "Emit diffuse" and "Emit specular" to image based lighting
    Лежит собственно здесь:
    http://www.illuminatelabs.com/download/beta2/Turtle3-beta2-win.zip
    http://www.illuminatelabs.com/download/beta2/Turtle3.0Beta2.dmg
    http://www.illuminatelabs.com/download/beta2/turtle-common-3.0.0-3.i386.rpm
    http://www.illuminatelabs.com/download/beta2/turtle-bin65-3.0.0-3.i386.rpm
    http://www.illuminatelabs.com/download/beta2/turtle-bin7-3.0.0-3.i386.rpm
    http://www.illuminatelabs.com/download/beta2/turtle3-manual-beta2.pdf
    http://www.illuminatelabs.com/download/beta2/turtle3-manual-beta2-html.zip
  2. Moderator. vip
    Moderator. Administrator Команда форума
  3. Пётр Вишняков
    Какие правила нарушает мой пост? Это свободная информация, краков я не предлагаю.
