Вопрос по картам в Zbrush
CRiM
Помогите разобраться с набором текста:) и как это сделать в Zbrush:
Color map - The "_color" texture can be 24 or 32 bit
Нужна Normal map - с этим разобрался
Mask1 -"_mask1" is a 32-bit texture and every channel is used.
Red is the detail map mask.
Green is the diffuse and fresnel warp mask.
Blue is the metalness mask which controls where the Color and Fresnel are suppressed. Works best in combination with mask 2 blue channel "tint specular by base color" which brings the color back through specular.
Alpha is the self-illumination mask, where the color is drawn from Color texture. Even if you are not using this, fill it with black and pixel of non-black in the corner of the material. This is done in order for texture compiler to keep this channel. If it is entirely black or white, it will be thrown out and the shader will think it's pure white
Mask2"_mask2" is 32-bit and again every channel is used.
Red is specular intensity.
Green is rimlight intensity.
Blue is "tint specular by base color", white color in this channel will color specular highlights by diffuse color from _color texture, black will keep specular highlights of whatever color light affecting the surface is.
Alpha is the scale factor of specular exponent from hero shader(vmt). For example, if the specular exponent is set to 16, then values for this channel of 0...255 will control exponent values from 0 to 16. Even if you are not using this, fill it with white and pixel of non-black in the corner of the texture. This is done in order for texture compiler to keep this channel. If it is entirely black or white, it will be thrown out resulting in a different texture format when compiled.
Alpha channel of 32 bit "_color"
The "_normal" texture should be 24-bit and use the 3dsmax format(red channel is left; green is up; blue is top). If you aren't creating a custom normal map, use a flat normal color (128,128,255).
CRiM
У меня какая то путаница с этими картами и для чего каждая из них нужна...
Если у кого есть то можно статью или описание подробное, что такое карты и вобще как с ними работать, в сети куча уроков где частями объясняется на допотопных версиях Збраш и не очень подробно... Можно даже на толковые платные уроки.
CRiM
т.е. Color map -карта текстур?
Нормали можно снять в збрашь после ретопа?
Остальное фотошоп?
CRiM
Оказалось что все можно делать плагином :) Multi-map exporter
Помогите пожалуйста по алгоритму работы:
1- Сделал хай поли модель с материалом, светом и тп.
2- Снял UV карту
3- Снял карту тексту с учетом материала
4- Сделал ретопологию в Zbrush (не топогане)
Потом нужно снять карты с лоу рез или хай рез, как я понял лоу рез должна идти поверх хай поли
Юви снимается с лоу поли а не хай поли,Применяется к хай поли и с хай поли снимаются карты на вставленую с лоу поли юви,
С той лоу поли которая получилась после ретопологии и которая будет в итоге (конечная),А не та с первого уровня дивайда твоей хай поли модели.
CRiM
Вот такая загогулина! Вобщем проверю вечером спасибо:)
Хотя смотрел видео урок где сначала делали UV развертку (UV мастером) с хай поли, потом перебрасывали хай поли в топоган и делали ретоп, а потом уже карты снимали в топогане. Меня это и путает, что многие видео уроки не стыкуются, все по разному делают и не объясняют почему именно так.
CRiM
А как текстуры снять, с хай поли, если UV карты только с лоу поли снимать?
CRiM
Я пересмотрел кучу туториалов, но так и не нашел ответа, как запечь карты между 2мя объектами в Zbrush... Однако в одном видеоуроке слышал, что якобы Збраш больше не умеет этого делать, что раньше это делал плагин Zmapper, так ли это?
