За то по словам Render Optimizations много чего, плюс то что тебе нужно:
The Render Optimization setting specifies how the Vector renderer optimizes the current frame to reduce file sizes. You can select one of the following types of optimizations:
Safe
Removes redundant geometry in areas of high detail, especially geometry that is only visible by zooming in on the area. Redundant edges occur on the at the intersection of the visible and invisible areas of the scene, and are always safe to remove.
Good
Removes redundant geometry in areas of high detail, and removes sub-pixel geometry that is not visible unless zooming into a high detail area.
Aggressive
Removes redundant geometry, sub-pixel geometry, and geometry that is slightly above the single pixel level, in high detail areas. This setting reduces file size by up to 30%.
Note
Using Aggressive optimization makes it possible to visibly detect the missing geometry without zooming in on the area. It may also result in inconsistent geometry (like unclosed shapes).
