вот нашел чтот то сам не пробовал еще
скажите если работает
- Install Poser 5, then the SR3 Figures Update & SR 3 update,
if you installed any other crack/patch/whatever, uninstall
then reinstall
- Verify the Exe version, should be 5.0.2.281, if not, you're
out of luck...
- With an Hex Editor, go to offset ACEF3 (hexa), you should see:
0F 85 5B 01 00 00
replace with
90 90 90 90 90 90
(yeah, noping a bloody jump)
- Now run Poser 5, it will ask about serial & name, enter something
if you wish (won't be saved, dunno, didn't check), or leave blank,
validate, validate again, you'll get a "quit or retry" window, hit
"quit"... and instead of quiting, Poser will run as if serial was okay.
The 'ugly' part of the crack is that you'll have to validate twice and
hit the 'quit' button each time you restart Poser... patching the windows
out is left as an exercice to the astute or finger-impaired reader.
