F1
About the Document Info palette
You use the Document Info palette to see listings of general file information and object characteristics, as well as the number and names of graphic styles, custom colors, patterns, gradients, fonts, and placed art. To display the palette, choose Window > Document Info.
• To view a different type of information, select an option from the palette menu: Document, Objects, Graphic Styles, Brushes, Spot Color Objects, Pattern Objects, Gradient Objects, Fonts, Linked Images, Embedded Images, and Font Details.
• To view information on only the selected object, choose Selection Only from the palette menu. Leaving this option deselected lists information about the entire document.
• To save a copy of the file information as a text file, choose Save from the palette menu. Specify a name and location, and then click Save.
