Пожалста объясните чайнику как приконектить максвел к майке
Тема в разделе "Maxwell Render", создана пользователем BlindHunter, 23 апр 2006.
  1. BlindHunter
    BlindHunter Пользователь сайта
    максвел версии 0.9(Beta) и майка 6.5. Конектор скачал, а что с ним делать не знаю.
  2. shidoxx
    shidoxx Знаток
    Mayall Windows Installation
    In this chapter you can get information about how to install Mayall in a Windows System
    You can setup and get Mayall running in a few steps
    Uncompress the fileMayall_071.zip in c:\.
    You need to setup several enviroment variables, in order to do it:
    go to: Start -> Control Panel -> System
    Into the System dialogue look into the Advanced Tab, Click on Enviroment Variables.
    If you a re installing the Plug-In for all the users use System Varibales, if you are installing only your user you can use User Variables too.
    Setup the next variables:
    MAYA_PLUG_IN_PATH = c:\mayall
    MAYA_SCRIPT_PATH = c:\mayall
    XBMLANGPATH = c:\mayall
    MAYALL_ROOT = c:\mayall
    The Maxwell install program must set you enviroment variable MAXWELL_ROOT to the Maxwell install dir, check it. If it doen's exists create your own MAXWELL_ROOT variable pointing to your Maxwell install dir, for example: if Maxwell isinstalled in c:\maxwell, set the enviroment variable to this path.
    Launch Maya and go to: Windows -> Settings/Preferences -> Plug-In Manager
    Go to c:/mayall folder and select mayall_maya60.mll for Maya 6.0 or mayall_maya65.mll for Maya 6.5 .
    Click on Load and Auto Load if you want that Mayall will be loaded every time Maya is launched.
    If you click on the Info button on the right tou can see the Mayall version.
    Enjoy Maxwell!
    ADVANCED: if you want to install Mayall in other location different than c:\mayall, you only need to substitute the c:\mayall path used before by your new mayall installation path.
