Error: MAXscript Rollout Handler Exception
Issue
You imported an fbx file from Revit that contains 'Pendant Light - Linear' lights. When you started the Light Lister from the Tools menu, you received the following error message:
Solution
This issue occurs because the default names of the Revit light objects contain double quotes (").
To correct this issue, you need to replace the Macro_LightList.mcr file. Follow these steps:
In Windows Explorer, browse to the macroscripts directory and locate the Macro_LightList.mcr file. For example:
C:\Program Files\Autodesk\3ds Max 2011\ui\macroscripts\
Rename the file, Macro_LightList__old.mcr.
Download the Macro_LightList.mcr file that is attached to this solution, and then save it to this directory.
Macro_LightList.mcr (mcr - 83Kb)
(http://images.autodesk.com/adsk/files/Macro_LightList.mcr)
с офф сайта автодиска
