Почему в Action не записываются Stamp и Healing Brush?
Почему-то не получается записать в экш работу штампом и лечащей кистью. Из "клонировщиков" записывается только Patch Tool.
Это такое ограничение проги или можно как-то обойти?
Не могу найти инфу по этому поводу.
pavel55555
Патамушта нииизяяя! Объяснять долго... просто прими это аки аксиому.
pavel55555
Из-за таких "суровых" лентяев как вы, форумы забиты простейшими/элементарными вопросами.
Неужели так трудно было найти ответ? Или вы на столько суровы, что гордыня/вера/идеология не позволяет найти за пару секунд.
USING ACTIONS IN PHOTOSHOP
....бла-бла-бла.............
PLANNING FOR AN ACTION
THEORY: "Plan the work and then work the plan" is an adage that will serve you well when you first think about creating an action. There are certain operations that actions can not perform. Knowing these operations in advance will help you better create actions. However, while actions may not perform some operations, there are workarounds that will assist you in getting your desired results. Typically, you can record steps that involve specific values (i.e., dialog box, transformation, etc.). You can also record freeform selections (Lasso, Ellipse, etc.).
APPLICATION: There are certain operations that you can not record. We will learn solutions to these operations to make the action behave the way we would like them to work.
AVOID SPECIFIC MEASUREMENT AND SELECTION:
  1. PROBLEM: If you create a selection of a specific size while recording, that size may not be applicable to other files.
    SOLUTION: Record the Select > All and then the Select > Transform in your action. Then hold down the ALT key to adjust the selection from its center and press the ENTER key to commit the transformation. Complete the action and then add a modal control to the Transform Selection step so that the user will be prompted to adjust the selection based on the image. Then press Enter to complete the selection as you normally would do and then complete the action.
  2. PROBLEM: If you record an action that include the Image Size or Canvas Size, the user will be prompted to enter a specific measurement. The images may not be all of the same size.
    SOLUTION: Use a percentage instead of a fixed unit of measurement (i.e., pixels).
AVOID CERTAIN MENUCOMMANDS OR OTHER SPECIALIZED TOOLS (i.e., BITMAP, VECTOR AND RETOUCHNING TOOLS)
  1. PROBLEM: You can not record certain tools that you have to use the MOUSE to perform a task:
    1. Retouching (Blur/Sharpen/Smude, Clone/Pattern Stamp, Dodge/Burn, Erase/Erase Background, Healing/Patch/Color Replacement
    2. Painting (Paint/History/Art brush)
    3. Selection (Path Selection, Direct Selection)
    4. Drawing (Pen and Pencil)
    5. Zoom
    6. Window and View menus
      SOLUTION: While you can not record with these tools, you can still perform most of them manually as you record. For instance, you can stroke a path with a Paintbrush option instead of using the Paintbrush tool itself.
      SOLUTION: You can add menu items by choosing the Inset Menu Item... command from the Action panel's flyout menu when a command was not added or needed to be added to an action. Choose a command you want to add. You can choose commands from the menu bar, or a panel's flyout menu but not a pop-up menus in panels. NOTE: The command will not be executed until the action is played and no value will be recorded. Commands that display a dialog box will pause the action for user's input. Once the user press OK, the action continues. Pressing Cancel will abort the action at a specific step and will need to be played again.
      SOLUTION:
      Choose Insert Stop from the Actions panel's flyout menu and give the user instruction on what they need to do (paint, draw, retouch) at a point in your action where you want these operations to occur. Make sure to check the Allow Continue checkbox. The major reason that you may want to uncheck the Allow Continue checkbox is if it is placed at the end of an action -- there would be no need to continue the action.
      TIP: The Insert Menu... can by used also to open a dialog box at its default values instead of the recorded values.
      NOTE: You can not use the View and Window menus.
