Всем читать Help (..\Help\1_15_4_8.html):
To wrap text around an object:
Select the object or objects around which you want the text to wrap. This is called the wrap object. (See Selecting objects.)
In the Layers palette, make sure that the wrap object is above the text you want to wrap around it. (See Organizing objects using layers.)
Important: If the layer contains multiple type objects, move any that you don't want to wrap around the wrap object either into another layer or above the wrap object.
Choose Object > Text Wrap > Make Text Wrap.
The Text Wrap Options dialog box appears. If desired, set the following options. Then click OK.
Offset to specify the amount of space between the text and the wrap object. You can enter a positive or negative value.
Invert Wrap to reverse the side of the object that the text wraps around.
Wrapped text with Invert Wrap deselected (left) compared to wrapped text with Invert Wrap selected (right)
To reset wrap options for an existing wrap object:
Select the wrap object.
Choose Object > Text Wrap > Text Wrap Options.
To unwrap text from an object:
Choose Object > Text Wrap > Release Text Wrap.
