Перемещение по рельефу
net 6152
Подскажите, пожалуйста, как лучше настроить перемещение объекта по рельефной местности? Можно, конечно, в качестве траектории задать сплайн, но очень трудно подогнать его под неровную поверхность так, чтобы модель, которая будет двигаться, не "проваливалась" через рельеф.
net 6152
А как проследить в таком случае провалы модели в поверхность?
И что такое shape merge? *8)
Simm_Andy
вот, ищи под шестерку. то, что тебе нужно.
Company: Digimation
Type: 3D animation
Glider is a set of two powerful space warps for 3D
Studio MAX that bind any object or particle system
to the surface of another object. Imagine how
difficult it could be trying to keyframe a car's
tires moving across a very rough terrain. Each
pothole and divot would have to be painstakingly
keyed so that the tire appeared to move correctly
and not pass through the surface. Object Glider
makes this process nearly automatic. Simply bind
the tires to the Object Glider space warp and
you're done! Now when the tires come into
contact with the ground they will automatically
adjust to conform to the topology. The second half
of Glider is the Particle Glider space warp. This
amazing plug-in gives you the ability to have
particles flow over another object's surface or
follow any 2D or 3D spline. Create precise smoke
trails, waterfalls that follow the landscape,
skywriting, liquid flowing through pipes and more.
Plus it recognizes most 3rd party particle
systems including Sand Blaster and Pandora, so
taming particles has never been easier! Glider
should appeal to anyone working with particle
systems inside 3D Studio MAX. It should be
especially appealing to those users who are doing
courtroom animations because of it's ability to
hold cars to roads, trains to tracks, etc. It is
the perfect companion to Atomizer and Clay Studio.
