Новый плугин от Максон Hairs
kathamrita
3D software developer MAXON is pleased to announce the first completely integrated professional CINEMA 4D module for the creation of hair, fur and feathers.
HAIR adds to MAXON's already impressive array of features for character designers. Characters will come alive through the combination of HAIR and the MOCCA module, which includes the cloth simulation tool, Clothilde. Naturally, all features work seamlessly together within CINEMA 4D. The editor view is updated in real time and the preview quality can be adjusted as desired.
Much attention was given to achieving a high level of interactivity. An extensive and intuitive toolset was created with over a dozen tools, such as brush, comb, curl and cut. The look of the hair is defined by a special HAIR shader. In addition to such properties as shine, frizz and thickness, a texture can also be loaded to define a color pattern for the hair.
Dynamic forces, including collision detection, can be used while styling and animating the hair. Forces such as gravity, wind, turbulence or twist can be used to create breathtaking animations. HAIR also offers an impressive cache functionality, which makes viewing the effects of dynamics or preparing a file for network rendering a breeze. Artists can even edit individual frames after they've been cached.
kathamrita
программный разработчик 3D MAXON рад заявить первому полностью встроенному профессиональному модулю CINEMA 4D для создания волоса, меха и перьев.
ВОЛОС добавляет к уже впечатляющему массиву MAXON's характеристик для символьных разработчиков. Символы придет живой через комбинацию ВОЛОСА и модуль MOCCA, которые включают имитационное средство ткани, Clothilde. Естественно, все характеристики работают полно вместе в пределах КИНО 4D. вид редактора скорректирован в течение реального времени и качество предварительного просмотра может быть скорректировано как захотеть.
Значительно внимание было дано достигающему высокому уровню interactivity. Расширенный и интуитивный toolset было создано включая свыше дюжины инструментальных средств, как например, щетка, гребень, вихрь и вырезанные. Взгляд волоса определен специальным ВОЛОСЯНЫМ shader. Дополнительно к таким свойствам как лоск, frizz и толщина, текстура может также загружена, чтобы определять цветной образец для волоса.
Динамические силы, включая обнаружение столкновения, может быть использовано пока стилистическая правка и одушевленная волос. Силы как например, тяжесть, ветер, волнение или искривление могут быть использованы, чтобы создавать захватывающие оживления. ВОЛОС также предлагает впечатляющее кеш функциональное назначение, которое делает рассматривая эффекты динамики или подготавливая файл к сети, предоставляющей бриз. Художники могут даже отредактировать индивидуальные фреймы после того, как они будут кешированы.
Gabba
Найдем - поиграемся. Если еще и встроенные возможности для генерации травы будут - то это сила!
TrigGer
А где такую штуку раздобыть если не секрет??? Киньте льнку, плиз. Кстати, фтпшник Максона че-то глючит ну нехочет с него качать. Может что подскажете?
kathamrita
Ночью все качается, я правда ReGet многозакачный применяю, может поэтому и не сбрасывает? Но Волоса пока они не выкладывали вроде. Он будет включен в Студию Бандл кажись.
TrigGer
Оч плохо. А хотелось бы так... Ну ни чо в принципе это дело тоже поправимое ведь так?
