http://www.edharriss.com/xsi/tools/Rq3beta3_zip
RenderQ (beta 3) v3.0 - By Arvid Björn - Website - RenderQ 3.0 supports Softimage XSI & Softimage 3D scene batch rendering, as well as Mentalray MI/MI2-file rendering, all in the same batch. Please note that it is still beta. This is BETA 3. Includes XSI options
http://renderq.net/download.html
RenderQ v4.3 - By Arvid Björn - Website -SOFTIMAGE XSI Render Farm Tool. Support for passes, RQ will retrieve them for you from the scene. Sequence segmentation, lets the user split the total sequence into smaller parts, thus preventing memory buildup. (the user defines number of frames per segment and RQ manages the rest, supports negative frames also) E-mail notification, RQ will send an email to any adress when the batch is completed. RQ will play a sound when the batch is completed. -guilic option implemented. Small render client that will launch your render every n:th second, unless one is already running. Also good for looping your batch to get around problems with crashes. Some common render options such as ZPIC, resolution, aliasing, sequences, output filename and path, image format, picture standard and field settings
не пробывал ?
