L Lexx 1395 Знаток 18 апр 2002 #1 Рейтинг 36 18 апр 2002 #1 Что там такого нового? Улучшился ли рендерер? Появился ли SSS и другие вкусности новомодные? Расскажите о новом ЛВ!
Guest 19 апр 2002 #2 19 апр 2002 #2 Вот что в мануале к 7,5 Viewport Changes......................................................1 The PathTool .......................................................................... 1 Bone X-Ray ............................................................................. 1 Motion Path Frame Markers ............................................... 2 OpenGL Specular Highlights ............................................... 2 About OpenGL dialog .......................................................... 3 Item Selection ......................................................................... 3 Motion Blur/DOF Preview .................................................. 4 Rotation Handles ................................................................... 5 Object Properties.......................................................5 SubPatches............................................................................... 5 Panel Organization Changes................................................ 6 Matte Object Option............................................................ 7 Unseen by Alpha Channel Option..................................... 7 Object Comments................................................................. 8 Sliders ....................................................................................... 8 Display Controls ...........................................................10 Add Slider Bank Command ........................................10 Depth of Field Display ........................................................10 Bone Changes...........................................................11 Faster Bones Option...........................................................11 Use Morphed Positions ......................................................12 Light Changes ...........................................................12 Shadow Color.......................................................................12 Spotlight View.......................................................................13 Light Properties Objects Tab............................................13 Caustics..................................................................................14 Radiosity.................................................................................14 Motion Modifiers ......................................................16 Simple Constraints ..............................................................16 Adding Constraints.......................................................16 Baking ..............................................................................18 Deleting Constraints ....................................................18 Simple Constraints vs. Parenter ................................18 Simple Affectors...................................................................19 Parenter .................................................................................19 Image Filters and Shaders ...................................... 19 Photoshop PSD Export ......................................................19 Flare2Alpha ...........................................................................21 SpriteEdger............................................................................21 Virtual Darkroom................................................................21 BRDF Surface Shader..........................................................22 Other Layout Changes ............................................ 22 Statistics Window................................................................22 Render Display .....................................................................22 Image Viewer........................................................................23 Extreme Antialiasing ...........................................................23 Depth Buffer Antialiasing ...................................................23 AutoDirectoryUpdate ........................................................24 Print Assistant Plug-in.........................................................24 Lightgen2lw Plug-in..............................................................24 CameraSelector Plug-in......................................................24 64-bit SGI Image Saver/Loader.........................................25 Expression Builder ................................................... 25 Powergons ................................................................ 26 What are Powergons..........................................................27 Executing the Commands..................................................28 Luxigons .................................................................... 28 Keyframer................................................................. 29 What is Affected..................................................................29 Affected Channels ...............................................................30 Affected Objects..................................................................30 Standard Tab.........................................................................31 Transfer Tab .........................................................................32 Other Tab..............................................................................33 BioVision Motion Capture Support........................34 Motion Preview....................................................................36 Spreadsheet ..............................................................37 Motion Mixer ............................................................38 Weight Curve.......................................................................40 Curve Translation................................................................40 Motion Instancing.................................................................40 TimeWarp Curves...............................................................41 Relative XZ Custom Offset Type....................................41 Character Custom Offset Type .......................................41 Motion Designer.......................................................42 Using Motion Designer with SubPatch Objects ...........42 Modeler .....................................................................42 Bandglue.................................................................................42 BandSaw Pro.........................................................................43 UV Spider ..............................................................................44 Magic Bevel............................................................................45
B Bravo Активный участник 22 апр 2002 #3 Рейтинг 16 22 апр 2002 #3 Nu chto ti za spisok tam privodish, shamanix?Govorya po prostomu, v LW7.5 est para principialnih novshestv:1-Vstroennii Dynamic Parenting,2-Vozmozhnost redaktirovat motion path pryamo v okne Layout.
Guest 23 апр 2002 #4 23 апр 2002 #4 кстати, с планшетом он стал работать гораздо лучше. так что изменений там много, может просто не сразу увидишь
