try(destroydialog igorznag_minOBB)catch()
rollout igorznag_minOBB "Min OBB"
--gui
button btn_apply "Apply"
--variables
local obj
--functons
-- The Jacobi Method for Finding the Eigenvalue and Eigenvectors
-- of Symmetric Matrices.
fn Jacobi n &a &d &v =
local i, j, p, q, rot, sm, g, theta, t, tresh, c, s, tau, h
local z=#()
local b=#()
for i =1 to n do
z[i] =0.0
b[i] = a[i][i]
d[i] = a[i][i]
for j=1 to n do
if (i == j) then v[i][j] = 1.0
else v[i][j] = 0.0
rot =0
for i =1 to 50 do
sm = 0.0
for p = 1 to n-1 do
for q=p+1 to n do sm += abs( a[p][q] )
if ( sm == 0 ) then exit()
tresh = case ( i<4 ) of
true: 0.2*sm/(n*n)
false: 0.0
for p =1 to n-1 do
for q = p+1 to n do
g = 1e12 * abs ( a[p][q] )
if ((i>4) and ( abs(d[p])>g ) and ( abs(d[q])>g )) then (a[p][q] = 0.0)
else
if ( abs( a[p][q] ) > tresh ) then
theta = 0.5 * ( d[q] - d[p] ) / a[p][q]
t = 1.0 / ( abs(theta) + sqrt(1.0+theta*theta) )
if ( theta < 0 ) then t = - t
c = 1.0 / sqrt ( 1.0 + t*t )
s = t * c
tau = s / ( 1.0 + c )
h = t * a[p][q]
z[p] -= h
z[q] += h
d[p] -= h
d[q] += h
a[p][q] = 0.0
for j=1 to p-1 do
g = a[j][p]
h = a[j][q]
a[j][p] = g - s * ( h + g * tau )
a[j][q] = h + s * ( g - h * tau )
for j=p+1 to q-1 do
g = a[p][j]
h = a[j][q]
a[p][j] = g - s * ( h + g * tau )
for j=q+1 to n do
g = a[p][j]
h = a[q][j]
a[q][j] = h + s * ( g - h * tau )
for j=1 to n do
g = v[j][p]
h = v[j][q]
v[j][p] = g - s * ( h + g * tau )
v[j][q] = h + s * ( g - h * tau )
rot += 1
for p =1 to n do
b[p] += z[p]
d[p] = b[p]
z[p] = 0.0
)--for i =1 to 50
return rot
)--fn Jacobi
fn GetBestFitVectors &v &dir &norm =
local n = v.count
if (n<2) then return false
local point = v[1]
for i = 2 to n do (point += v[i])
point /= n
local xx, xy, xz, yy, yz, zz
xx = xy = xz = yy = yz = zz = 0.0
for i = 1 to n do
local u = v[i] - point
xx += u.x * u.x
xy += u.x * u.y
xz += u.x * u.z
yy += u.y * u.y
yz += u.y * u.z
zz += u.z * u.z
--Symmetric Matrix
local a = #([ xx, xy, xz ],
[ xy, yy, yz ],
[ xz, yz, zz ])
--Eigenvalue
local d = #(0.0, 0.0, 0.0)
--Eigenvectors
local u = #([ 0, 0, 0 ],
[ 0, 0, 0 ],
[ 0, 0, 0 ])
--finding the Eigenvalue and Eigenvectors
jacobi 3 &a &d &u
-- calc direction ray
if ( d[1] >= d[2] ) then
if ( d[1] >= d[3] ) then (dir = [ u[1].x, u[2].x, u[3].x ])
else (dir = [ u[1].z, u[2].z, u[3].z ])
else
if ( d[2] >= d[3] ) then (dir = [ u[1].y, u[2].y, u[3].y ])
-- calc normal fit plane
if ( d[1] <= d[2] ) then
if ( d[1] <= d[3] ) then norm = [ u[1].x, u[2].x, u[3].x ]
else norm = [ u[1].z, u[2].z, u[3].z ]
else
if ( d[2] <= d[3] ) then norm = [ u[1].y, u[2].y, u[3].y ]
return true
)--fn GetBestFitVectors
on btn_apply pressed do
undo off
max modify mode
objs=selection as array
for i=1 to objs.count do
obj = objs[i]
if(classOf(obj)==Editable_Poly)then
-- get cloud points from object
cloud_points = #()
for i=1 to obj.NumVerts do append cloud_points (polyOp.getVert obj i)
-- calc fit dir and normal fit plane
getBestFitVectors &cloud_points &dir &norm
-- calc and draw box
arr=#(); join arr cloud_points
local upVector = normalize ( cross dir norm )
local T = matrix3 upVector norm dir [0,0,0]
local iT = inverse T
for i=1 to arr.count do arr[i] = arr[i] * iT
local qmin = copy arr[1]
local qmax = copy arr[1]
for i in arr do (
for j=1 to 3 do (
if i[j] < qmin[j] do qmin[j]=i[j]
if i[j] > qmax[j] do qmax[j]=i[j]
local _diag = qmax-qmin
local l = abs _diag.x
local w = abs _diag.y
local h = abs _diag.z
local b = box length:w width:l height:h
b.pivot = b.center
b.transform = T
b.pos = (qmax+qmin)/2.0 * T
b.wirecolor = obj.wirecolor
b.name=obj.name
b.parent=obj.parent
b.pivot=obj.pos
for obj_child in obj.children do append b.children obj_child
b=converttopoly b
polyOp.deleteFaces b #{1..(polyop.getNumFaces b)}
polyOp.attach b obj
selectmore b
)--if(classOf(obj)==Editable_Poly)then
)--for i=1 to selection.count do
)--undo off
redrawViews()
)--on btn_apply pressed do
); createdialog igorznag_minOBB 100 30
