Gentoo + Maya 8.5 (sp1)
NemesisSOAD
Ставил по инструкции с http://gentoo-wiki.com/HOWTO_Install_Autodesk_Maya_8.5 при запуске выдаёт ... Illegal instruction , тобишь всё плохо. strace выдаёт (конец лога )
sigreturn() = ? (mask now [INT CHLD])
rt_sigprocmask(SIG_BLOCK, [CHLD], NULL, 8) = 0
rt_sigprocmask(SIG_SETMASK, [INT], NULL, 8) = 0
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7d09000
write(4, "Illegal instruction\n", 20Illegal instruction
) = 20
rt_sigprocmask(SIG_UNBLOCK, [INT], NULL, 8) = 0
close(3) = 0
close(4) = 0
close(5) = 0
close(0) = 0
close(1) = 0
close(2) = 0
rt_sigprocmask(SIG_BLOCK, [INT], NULL, 8) = 0
close(0) = -1 EBADF (Bad file descriptor)
dup(19) = 0
ioctl(0, FIONCLEX) = 0
close(1) = -1 EBADF (Bad file descriptor)
dup(17) = 1
ioctl(1, FIONCLEX) = 0
close(2) = -1 EBADF (Bad file descriptor)
dup(18) = 2
ioctl(2, FIONCLEX) = 0
lseek(16, 0, SEEK_END) = 7269
close(0) = 0
close(1) = 0
close(2) = 0
read(16, "", 4096) = 0
ioctl(16, SNDCTL_TMR_TIMEBASE or TCGETS, 0xbf826dc8) = -1 ENOTTY (Inappropriate ioctl for device)
exit_group(132) = ?
в make.conf сейчас
CFLAGS="-march=athlon-tbird -O2 -pipe -fomit-frame-pointer"
CXXFLAGS="${CFLAGS}"
# This should not be changed unless you know exactly what you are doing. You
# should probably be using a different stage, instead.
CHOST="i686-pc-linux-gnu"
FEATURES="parallel-fetch ccache"
GENTOO_MIRRORS="http://gentoo.osuosl.org/ "
SYNC="rsync://rsync.gentoo.org/gentoo-portage"
USE="nptl nptlonly -ipv6 -fortran unicode samba opengl alsa svg hal dbus \
kde qt3 qt4 -gnome -gstreamer -firefox"
LINGUAS="ru"
донедавна было вместо CFLAGS="-march=athlon-tbird -O2 -pipe -fomit-frame-pointer" стандартый i686
в ядре поддержка процессора включена - посоветйте что -нить.
gentoorion
write(4, "Illegal instruction\n", 20Illegal instruction) = 20
в этот момент уже Illegal instruction случился. Т.е. все интересное выше. Приведенный хвост - закрытие пускалки
чего-то, что дало llegal instruction.
strace -f вам может помочь.
В rpm должны быть spec-и, как была собрана Maya. Надо, чтобы ее окружение было собрано так же.
А вообще, если не очень разбираетесь во внутренностях Linux - поставьте RedHat, для которого собраны
упомянутые rpm. Там все, скорее всего, будет работать как надо. Разница с gentoo будет небольшой
по производительности, а траха с настройками меньше. Gentoo - девелоперская система прежде всего.
NemesisSOAD
[pid 4987] read(7, "any -snh/setNoSelectionHeadsUp f"..., 4096) = 4096
[pid 4987] read(7, "nel = \"Unknown channel type: ^1s"..., 4096) = 4096
[pid 4987] read(7, "is obsolete and no longer does a"..., 4096) = 4096
[pid 4987] read(7, "_blur2d.rForward = \"Forward\"\ns_b"..., 4096) = 4096
[pid 4987] read(7, "t EPS file : Disk is Full.\"\ns_da"..., 4096) = 4096
[pid 4987] read(7, ";*.iff;*.jfif;*.jpeg;*.jpg;*.pic"..., 4096) = 4096
[pid 4987] brk(0x85a7000) = 0x85a7000
[pid 4987] brk(0x859f000) = 0x859f000
[pid 4987] read(7, "\\tvideo mode for yuv files\\n\\t-C"..., 4096) = 4096
[pid 4987] read(7, "oveEdge\"\ns_polyEdit.rTpolyMoveFa"..., 4096) = 2733
[pid 4987] read(7, "", 4096) = 0
[pid 4987] close(7) = 0
[pid 4987] munmap(0xb0044000, 4096) = 0
[pid 4987] brk(0x85c5000) = 0x85c5000
[pid 4987] open("/dev/zero", O_RDWR|O_LARGEFILE) = 7
[pid 4987] brk(0x85e6000) = 0x85e6000
[pid 4987] gettimeofday({1188388272, 521456}, {0, 0}) = 0
[pid 4987] gettimeofday({1188388272, 521712}, {0, 0}) = 0
[pid 4987] gettimeofday({1188388272, 521946}, {0, 0}) = 0
[pid 4987] gettimeofday({1188388272, 522181}, {0, 0}) = 0
[pid 4987] --- SIGILL (Illegal instruction) @ 0 (0) ---
Process 4987 detached
<... rt_sigsuspend resumed> ) = ? ERESTARTNOHAND (To be restarted)
--- SIGCHLD (Child exited) @ 0 (0) ---
wait4(-1, [{WIFSIGNALED(s) && WTERMSIG(s) == SIGILL}], WNOHANG, {ru_utime={6, 4375}, ru_stime={0, 320020}, ...}) = 4987
wait4(-1, 0xbfaaa238, WNOHANG, 0xbfaaa1f0) = -1 ECHILD (No child processes)
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7d36000
) = 20
получается время системное не может выкупить?
Скорее всего какой-нибудь модуль в ядре выключен, но гадать какой - практически бесполезно...может hardware clock, но их там штуки 3, этих часов, плюс разновидностей ещё десятка два.
gentoorion
самый простой из всех и самый доступный
может unicode барахлит. Если программа собрана без unicode, то ожидает другие размеры строк.
Illegal instruction, в частности, от переполнения буфера может случиться.
NemesisSOAD
lol )) я насчёт собрать только могу мечтать ))) т.к. в рпм-ке она походу уже того... собранная ))
Локаль у меня ты прав в UTF-8 а насчёт переполнения буфера почитаю т.к. всё вышеперечисленное случается после [pid 4987] open("/dev/zero", O_RDWR|O_LARGEFILE) = 7
[pid 4987] brk(0x85e6000) = 0x85e6000 . а /dev/zero это файл подкачки (.
gentoorion
собрать систему без unicode. я про это.
Попробуйте проверить maya собрана с unicode или без. Там в rpm бывают spec файлы.
Из них это можно выдавить. Ибо если без, то все понятно. Система возвращает
maya какой-то текст, а maya предоставляет маленький буфер, происходит переполнение
и illegal instruction
NemesisSOAD
ок попробую )) как сделаю отпишусь )) ( хочу попробовать под vmware собрать ещё одну систему и там глянуть )
gentoorion
vmware - терпеливый парень, однако.
В данном случае xen будет более к месту.
NemesisSOAD
прошу прощения что не отписываюсь - пришлось сменить карточку на ati - то бишь проблем добавилось. Как закончу разбиратся с атихой отпишусь.
Sahafa
Или
Или вариант поставить Mandriva Linux 2007 powerpack или powerpack+. Прекрасно Maya работает и поставилась без проблем. И система нравится.
NemesisSOAD
Sahafa
хы да я только я такой человек что меня хлебом не корми дай самому поковырять настроить ...
Ну вобщем я отвлёкся .... вобщем залепил я вчера на тачилу Opteron 170 ,2gb 64 битный дистрибутив gentoo вобщем после настройки всего и вся в частности по привычке влепил utf-8 до ну думаю чем чёрт не шутит ай-да попробую - майку на 64 битах - не поверите всё запустилось - .. сказать что быстрее работает - не сказать ничего. Вобщем ща на работе пересобираю систему мож чё получится ((.
gentoorion
то приноси свою маю ко мне на кластер. Вполне возможно,
что организуем параллельный рендер к обоюдной выгоде наших организаций.
NemesisSOAD
Хы у меня ширины канала не хватит бодатся (( да и 170 оптерон не такая уж и сильная на данный момент система. Конфиг я запостил по причине установки 64 битного дистрибутива. Факт больше в том что она работает - хотя ничего лишнего я не ставил .... набор ПО одинаков на двух машинах, настройки ядра (кроме спецефических (SATA,CPU,и т.д.) тоже. локаль такая-же но вот беда на этой работает а на той нет. Ладно денёк подожду пока всё соберётся ((. Хммм я тут подумал - может пора завязывать на stage3 и возвращатся на stage1 всё равно в итоге один хрен получается .... ?
gentoorion
stage3 можно, но после перекомпилить все. Это эквивалентно stage1, просто избавляет от колец зависимостей вначале
Бодаться не надо, финальный результат, если проект приличный можно и ножками забрать. А на превьюшки хватит
узкого канала, как я понимаю.
Потом, канал на сегодня 2200 кбит до $30 в мес частным лицам. Должно хватить.
NemesisSOAD
Хы)) давно не заходил. Насчёт stage3 ты прав на 100% пересборка очень важна, странно что на спец сайтах об этом ни слова хотя от глюков избавляет на 100% , ввиду того что поставленно было уже очень много я решил собрать систему с нуля , естественно всё пересобрав я не стал менять привычную мне локаль и с замиранием сердца поставил майку , как и ожидалось всё заработало. Жалко л.с. нету яб аську скинул мож чё придумалиб))
з.ы. попозже создам почтовый ящик напишу адресок сюда дык пообщаемся )).
