Fusion 6.31
Тема в разделе "Eyeon Fusion & Generation", создана пользователем Григорий Чаленко, 1 мар 2012.
Модераторы: Григорий Чаленко
  1. Григорий Чаленко
    Григорий Чаленко Moderator Команда форума
    Юбилейный билд 1000:
    http://www.eyeonline.com/Web/EyeonWeb/Downloads/DownloadFusion.aspx
    Список нововведений:
    http://vfxpedia.com/index.php?title=Eyeon:Manual/Fusion_6/Fusion_6.3.1_Build_1000
    Особо хороши:
    • Tool names in input expressions are no longer adjusted when the tool is renamed, if the input is instanced, as this will cause the expressions on the instance parent to get renamed too, eg. when pasting a new instance (исправляет ошибку с инстансингом многих макросов)
    • Various menus are now customisable using Fusion.menus stored in the Profile: path, similar to Fusion.hotkeys.
    • The status bar will show the file path when navigating main Tools\Macro or Scripts main menus.
    • Toggle buttons in multi-button controls now show as ‘pushed’.
    • Changed the order that input and output data types are checked/changed in pipe routers, which might help them keep their output datatype as that of the upstream tool, rather than keeping their input the same as the downstream tool. This should hopefully allow image tools connected to a mask input, via a pipe router, to show the extra mask related options, as it’s still an image type feeding into the downstream tool, rather than a mask type (в некоторых макросах до этого не отображались все параметры масок, если в качестве маски использовалась RGB-картинка)
    • Can now display any single aux channel. The channel popup only shows channels in the image. Also supports viewing channel groups as RGB. Two channel groups will show as RG.
    • Added a ‘difference’ stereo mode (теперь можно легко сравнивать две картинки дифференсом без дополнительного Мерджа)
    • Added an option for sorting the tools in the timeline by their first valid frame.
