Enthropy2Slim Article: Where Are You?
Тема в разделе "RenderMan", создана пользователем -, 23 ноя 2001.
Модераторы: Moderator.
    Gde to stat'ju chital kak prikrutit' Enthropy k Slim (MTOR). Bila ona na samom chto ne na est' russkom jazike...kazhetsja na www.3dfly.com.
    Kinulsja ja tut ee chitat' - a sait to ne rabotaet - kanul rodnen'kii vmeste s dragozennoy stat'ey. Est' li enta stat'ja gde eshe - ne beda esli i na Anglizkom!
    Thanks in advance!
    На счет Entropy пока не получается, а вот как подружить BMRT с MTOR, то читай в оригинале на:
    http://www.deathfall.com/
    там, к стати, много чего интересного :)))
    Удачи!
    Hi to use slim shaders with entropy do that:
    1) Create a entropyCompile.bat file that contains only this string
    sle -I%2 %1
    and put it in your Exluna\Entropy\bin folder
    2) In Slim->Preferences->Expert put the following string in second compiler text field
    compilarEntropy %f %I
    3) Change the Slim workspace root in order to avoid spaced names problems (such as "Documents and Settings). For example create a folder named Shaders in your hard disk root
    4) Now when you create a shader in Slim and compile it (Pressing on the preview icon) you'll see that in you rmshader folder 3 files are created: one with extension .SL (Source renderman code) one qith ext .SLO (Renderman compiled shader) and one with ext .SLE (Entropy compiled shader)
    Thay's all
    Bossrobot
