Извини за опоздание, вот инструкция, я думаю тут все понятно:
1 - Install PSD-Manager and IP-Clamp license server and set it up.
2 - Launch IP-Clamp.exe and go to the "Settings" tab, choose "localhost" as Primary Network Adapter,press apply.
3 - Go to the "Request" tab and enter this License Code : *****-*****-*****-*****
Fill in all the fields (User Name, State, e-mail, etc).
Select the network adapter you want to lock license to "Manage Licenses locked to ID..."
Press "Add" then "Request" and choose a name (e.g: lic_request.txt) for the request file, press "Save".
4 - Fire up our keygen (XF-DieCebas.exe).
In the upper field, click the browse button and select the request file you just created.
Still in the keygen, click on the browse button in the lower field and select where to store the generated license file.
BEWARE! NOT IN THE IP-CLAMP FOLDER! ANYWHERE YOU WANT BUT NOT THERE!
Finally, press "Generate". If no error has been reported you now having license for your computer for *ALL* Cebas products that use IP-Clamp.
5 - Back in IP-Clamp.exe go to "Licenses" tab and press "Import Licence".
Point out the ipclamp.lic license files generated above... if everything went OK it will list all the licenses in the "License" tab.
6 - Enjoy this AWESOME release from X-FORCE!
PS: TROUBLESHOOTING:
If you have a network adapter but it's not listed in the IP-Clamp interface you need to make sure your local IP address is a valid one.
Check the FAQ in the IC-Clamp help to see what's a valid local IP address.
If nothing work, as a last resort you may pick "Softlock" as adapter. The licenses will then be locked to your primary Hard Drive Disk serial number.
