Азы Rhino или как научиться работать с нуля
Moi vopros, v printsipe, uzhe v teme soobsheni'a.
Ia ishu kakuiu-nibud horoshuiu pomosh (zhelatelno v internet ili po e-mail), chtobi nauchitsia rabotat s Rhino. Ia eshe prakticheski ne zanimalsia 3x-mernim modelirovaniem, tak chto eto dolzhno bit deistvitelno samoe nachalo.
Zaranee spasibo vsem za pomosh.
Your Cyberlord
Dlia Rhino est' kurs ! v .pdf ! esle u tebia horoshii kanal mogu skinut'
po emailu , tebia netkot nebudet uchit' netu lohov zdes' !
Ia i ne imel vvidu chto menia nado uchit po e-mail'u! v printsipe, ia nadeialsia, chto u kogo-to est pdf ili doc-file s uchebnikom. esli ne trudno, namil mne etot pdf po adresu rywlin@gmx.de. zaranee blagodaren. Cyberlord
Для начального освоения Рины достаточно прочитать имеющиеся в ней туторы: замок, фонарик и утёнка.
Dlja nachal'nogo osvojenia Rhiny dostatochno prochitat' imejuschiesja v nej tutory ('Tutorials'): zamok, fonarik i utjonka.
Help -> Tutorials
1. Start using Rhino (замок, zamok)
You will use Rhino's basic navigation tools, shaded preview, and render to create fundamental geometric objects. These short tutorials give you a start using Rhino's navigation and surface creation tools.
2. Build a model with solids (фонарик, fonarik)
While making a simple model of a flashlight you will create accurately sized solids, combine the solids together, and render.
3. Create organic shapes (утёнок, utjonok)
Focusing on flexible, free-form shapes, you will create and edit surfaces by manipulating control points, draw curves, blend between surfaces to create a rubber duck toy and then render the model with lights.
Est' PDF, 2 fila.pdf + Modeli k oboim uchebnikam
Po emailu ia nichevo nebudu skidivat', esle est' kanal to mogu zakachat'
