Autodesk Toxik
mad_s
Весьма любопытная тема - http://www.highend3d.com/boards/showflat.php?Cat=&Board=thebuzz&Number=202007
"Key Features in Toxik
* Creative tools: Advanced compositing toolset for visual effects creation, including tracking, keying, HDRI and standard color correction and rotoscoping tools
* Enterprise collaboration: Simultaneous multi-user access to centralized media and meta-data; composition versioning
* Ultra High-Resolution Interaction: Fast display and fluid manipulation of extremely large images (4K, 8K, even 21K+)
* Reaction: Autodesk’s next-generation 3D compositing environment
* Suave: Reaction’s 32-bit float, high-quality, HDR-capable software renderer
* Touch UI: A unique gestural user interface for fast on-screen compositing interaction
* Highly-optimized, 32-bit float and 16-bit half-float HDR processing pipeline
* Efficient, node-based procedural compositing system with advanced animation capabilities
* Flexible, modular software architecture, comprehensive API and full Python scripting capabilities for superior facility integration, process automation and workflow customization "
Особенно интересно: "Toxik is designed to extract the maximum performance from Intel®-based workstations and the NVIDIA® Quadro® FX series of graphics cards for Windows-based operating systems. North American pricing for one Toxik creative seat with supporting collaboration infrastructure is $9,000 USD. Toxik 1.0 begins shipping worldwide in mid-April 2005 (at NAB)."
mad_s
причем я было подумал что это первоапрельский фэйк, ан нет, пресс-релиз от 31-го марта
This ifs pretty cool and VERY Expensive tools. The only profit - to use at the big production facility. It looks like AudoDesk is trying to re-use their technologies from ACAD ( Oracle based CVS). And the price 9000 per license - is only for the beginnning - you have to pay for support, setup etc up to 2500 ... each month.
ОЧЕНЬ большой дистрибутив (только сервер БД весит 620 метров)
aka_tt
блин. Toxic Permit Server не стартует. выдает кучу каких то ошибок... кто уже поставил-запустил?
ХЗ... Качал не я - объёмов не знаю. Работает или нет - тоже. Хотя читал, что кто-то запустил, а кто-то и поставить не может.
aka_tt
там история какая - в конце установки тохик пробует создать дб в оракле. ему это не удается. если при этом не отменять установку а полезть в дебри того что уже поставимлось - оказывается что не подтыкается feature toxik из лицензии. может быть и еще чтото неработает - но я остановился на этом. и так называемый permit server который надо указать при создании этой ДБ тоже не стартует - выдает гору какихто сообщений и останавливается
Запустил!
На мой взгляд полная Х...ня!
Grain Match отсутствует, маски проше чем в Combustion.
Продукт сырой, многое упушенно, пока достаточно сложно.
По организации очень сильно напоминает Cyborg.
Но он хотя-бы на WildCut работал с SD в realtime.
Этот на FX 4000(реальной) и RAID(250 mb/sec) еле еле шевелиться.
Будем разбираться.
Пока легкое разочарование.
легкое это мягко сказано..
отсуствуют при первом знакомстве две оснвный состовляющие всех нормальных композеров..
отсуствуют в удобоваримом формате...
то что есть полное г...
как сборщик сцены для супервизера может и прокатит...
но как поноценный пакет...
подождем выхода версии 3.0
оговорюсь ето на первый взгляд...
но если копать надо так глубоко чтобы найти простые добавки шейповк имеющимся маскам...
добавить к единственной точке трекера еще одну...
надо потратить хотябы пару денй..
это не есть удобна...
ето не есть революция..
aka_tt
пермит сервер так и не запустился. перепробовал 3 совершенно разных железных конфигурации. вин хп, вин хп сп1, вин хп сп2 - один х... - пермит вываливается с длиннющим мессиджем об ошибке (ошибках)
#16
А у кому-нибудь удалось клиента на отдельной машине запустить?
На Quadro 1100 все в релтаме мы все в шоке были, это революция!!!
Discreet the best!
#17
Что-то разнополярные мнения: то отстой, то - революция...
timg, а кроме Quadro что ещё в машине (cpu, ram, hdd, OS)? И в каком разрешении реалтайм?
#18
ПАЛ...
плюс кеш для рилтайма создается гига так на 4...
вобщем запасайтесь аренами....
террабайтными..
#19
Тимофей привет!
Расскажи о реалтайме, а то что-то по моим ошущения реалтайм там есть, но не во всем. Иногда подбешивает кеширование всего.
#20
Киборг плагинов больше, есть примат.
Toxik - пока не все понятно. На амд с ССЕ 2 не работает.
На P4 3600 NV6600 2Gb тормозит и гораздо меньше в памяти материала для риал тайма. Работа с рейдом почемуто заторможена.
Вот такая революция (
Короче киборг функциональней по части инструментов, но отсутствует поддержка OpenEXR и кое что ишо.
More responsible.
