Анализ Sample rate на Unified/raytraced
Тема в разделе "Mental Ray", создана пользователем JohnJonny, 22 май 2016.
Модераторы: Alex Kras
  1. JohnJonny
    JohnJonny Пользователь сайта
    Здравствуйте
    Есть ли способ в 3dsmax mental ray на адаптивном режиме glob sampling(unified) посмотреть карту samle rate ? вкладка diagnostics не работает (работает только с classic). В майке есть ,в максе не могу найти способ!
  2. ЕС_Петров
    ЕС_Петров Активный участник
    Тоже заметил такую "фичу". Присоединяюсь к вопросу. :Nerd:
    JohnJonny нравится это.
  3. mikinik
    mikinik Активный участник
    не смотрел в хелпе к SA менталу, если есть что может в максе стрингами можно?
  4. JohnJonny
    Diagnostic Modes
    grid on all objects in the scene visualizing the coordinate space given. The distance between grid lines is S units. This is useful to estimate the size and distances between objects and to visualize the object space of objects. The off argument turns this mode off.
    diagnostic bsp off|depth|size
    This mode visualizes the depth and leaf size of the BSP tree used for ray tracing acceleration. This works only if ray tracing is enabled ( trace on) and the regular BSP algorithm is used (acceleration bsp). (It does not work for large bsp.) Both modes are the default. The image is scaled so that black means zero depth or size, and red or white means highest depth or size encountered (the absolute values are shown in the message output if the verbosity is 4 or higher). BSP diagnostics can be used to check how often the maximum BSP depth and the maximum leaf size were reached, as specified with bsp depth and bsp size statements. If this happens frequently, the parameters should be increased.
    diagnostic photon off|density|irradiance N
    When using photon maps, this mode replaces all material shaders in a scene with an internal shader that produces a irradiance components. Photon density is the number of photons per unit surface area. N is the density (or irradiance) that is assigned to 100%, or red. The colors are, from 0% to 100%: blue, cyan, green, yellow, and red. Higher values fade to white. N can be given as zero in which case the appropriate maximum is automatically found. This mode is useful when tuning the number of photons in aphoton map and setting the various accuracy options, since the density (or irradiance) is estimated using those settings. The off argument turns this mode off.
    diagnostic samples on|off
    This mode replaces the rendered image with a grayscale image showing the number of image samples made for each pixel. A black pixel has had no samples, whereas a white pixel has had the maximum amount as specified with the -samples option. In addition, a red grid is drawn indicating task boundaries. Samples that lie exactly on pixel boundaries are considered to belong to the lower and/or left pixel. This mode is useful when tuning the samples and the contrast options for optimal effect.
    diagnostic finalgather on|off
    This mode shows final gathering points, as green dots for initial raster-space final gathering points, blue dots for final gather points from per-object finalgather map files and red dots for render-time final gathering points.
    Есть список команд , но как в максе их применить ?
    Listener пишет ошибку, что не удивительно.
  5. JohnJonny
    Выяснилось , что такой возможности в 3dsmax нет!
    Весомый аргумент в пользу Майки!
    Спасибо
  6. mikinik
    JohnJonny, то есть это исключительно майская фича? как в майе это выглядит? если есть в SA версии ментала то думаю и в максе можно через стринги включить.
  7. JohnJonny
    На autodesk мне ответили , что да - такая функция существует и нет- в максе она не реализована, в отличии от mr sa, maya , softimage.
    В максе кстати много чего работает в ментале только с classic.
