Как только проходит инициализация и установка 9x DiretX выскакиет сообщение о прекращении установки в связи с причиными указаными в логе. Открываю лог и ничего не понятно. Помогите разобраться пожалуйста!
2010/3/26:00:36:16 User COMP === Installation started on COMP by User ===
2010/3/26:00:36:16 User COMP Install MSI Runtime 3.1 Skipped Windows Installer upgrade is not required. System Version = 4.5.6001.22159
2010/3/26:00:36:16 User COMP Execute ..\support\directx\dxsetup.exe /silent
2010/3/26:00:36:16 User COMP Running "F:\Installs\support\directx\dxsetup.exe" /silent
2010/3/26:00:36:49 User COMP Install DirectX 9.0c Succeeded Command = "F:\Installs\support\directx\dxsetup.exe" /silent
2010/3/26:00:36:49 User COMP Install .NET Framework Runtime 2.0 Skipped .NET Framework Runtime upgrade is not required. System Version = 2.0.50727.0
2010/3/26:00:36:49 User COMP Execute ..\support\MS-Hotfix\NDP20-KB918842-X86.exe /quiet /l*v %temp%\3dsmax9_win32_Install.log
2010/3/26:00:36:49 User COMP Running "F:\Installs\support\MS-Hotfix\NDP20-KB918842-X86.exe" /quiet /l*v C:\DOCUME~1\User\LOCALS~1\Temp\3dsmax9_win32_Install.log
2010/3/26:00:38:29 User COMP Install .NET Framework Runtime 2.0 Hotfix Succeeded Command = "F:\Installs\support\MS-Hotfix\NDP20-KB918842-X86.exe" /quiet /l*v C:\DOCUME~1\User\LOCALS~1\Temp\3dsmax9_win32_Install.log
2010/3/26:00:38:29 User COMP Execute ..\support\DWF\SetupDWFViewer.msi /qb
2010/3/26:00:38:29 User COMP Running msiexec /i "F:\Installs\support\DWF\SetupDWFViewer.msi" /qb
2010/3/26:00:38:39 User COMP Install Autodesk DWF Viewer 7 Succeeded Command = msiexec /i "F:\Installs\support\DWF\SetupDWFViewer.msi" /qb
2010/3/26:00:38:39 User COMP Execute 3dsmax9_win32.msi /L*v %temp%\3dsmax9_win32_Install.log
2010/3/26:00:38:39 User COMP Running msiexec /i "F:\Installs\3dsmax\3dsmax9_win32.msi" /L*v C:\DOCUME~1\User\LOCALS~1\Temp\3dsmax9_win32_Install.log
2010/3/26:00:38:39 User COMP Install Autodesk 3ds Max 9 Failed Installation aborted, Result=5
2010/3/26:00:38:39 User COMP === Installation ended ===
