Удалил макс по причине корявого руссификатора,опять устанавливаю,и через некоторое время выбивает ошибку с сылкой на следующий файл
2010/2/1:21:10:53 User COMP === Installation started on COMP by User ===
2010/2/1:21:10:53 User COMP Install MSI Runtime 3.1 Skipped Windows Installer upgrade is not required. System Version = 3.1.4000.4104
2010/2/1:21:10:53 User COMP Execute ..\support\directx\dxsetup.exe /silent
2010/2/1:21:10:53 User COMP Running "H:\Soft\3ds max\Installs\support\directx\dxsetup.exe" /silent
2010/2/1:21:11:02 User COMP Install DirectX 9.0c Succeeded Command = "H:\Soft\3ds max\Installs\support\directx\dxsetup.exe" /silent
2010/2/1:21:11:02 User COMP Install .NET Framework Runtime 2.0 Skipped .NET Framework Runtime upgrade is not required. System Version = 2.0.50727.0
2010/2/1:21:11:02 User COMP Execute ..\support\MS-Hotfix\NDP20-KB918842-X86.exe /quiet /l*v %temp%\3dsmax9_win32_Install.log
2010/2/1:21:11:02 User COMP Running "H:\Soft\3ds max\Installs\support\MS-Hotfix\NDP20-KB918842-X86.exe" /quiet /l*v C:\DOCUME~1\User\LOCALS~1\Temp\3dsmax9_win32_Install.log
2010/2/1:21:13:23 User COMP Install .NET Framework Runtime 2.0 Hotfix Succeeded Command = "H:\Soft\3ds max\Installs\support\MS-Hotfix\NDP20-KB918842-X86.exe" /quiet /l*v C:\DOCUME~1\User\LOCALS~1\Temp\3dsmax9_win32_Install.log
2010/2/1:21:13:23 User COMP Execute ..\support\DWF\SetupDWFViewer.msi /qb
2010/2/1:21:13:23 User COMP Running msiexec /i "H:\Soft\3ds max\Installs\support\DWF\SetupDWFViewer.msi" /qb
2010/2/1:21:13:29 User COMP Install Autodesk DWF Viewer 7 Succeeded Command = msiexec /i "H:\Soft\3ds max\Installs\support\DWF\SetupDWFViewer.msi" /qb
2010/2/1:21:13:29 User COMP Execute 3dsmax9_win32.msi /L*v %temp%\3dsmax9_win32_Install.log
2010/2/1:21:13:29 User COMP Running msiexec /i "H:\Soft\3ds max\Installs\3dsmax\3dsmax9_win32.msi" /L*v C:\DOCUME~1\User\LOCALS~1\Temp\3dsmax9_win32_Install.log
2010/2/1:21:13:32 User COMP Install Autodesk 3ds Max 9 Failed Installation aborted, Result=5
2010/2/1:21:13:32 User COMP === Installation ended ===
в чем дело?такое раньше было-я систему менял...сейчас нехочу переустанавливать...
