Я работаю в Fusion и пытаюсь использовать ноду Camera Tracker для отслеживания видео, но постоянно получаю следующую ошибку:
Solve failed: not enough tracks Mathematically, there must be at least 8 tracks in common between consecutive frames to reconstruct the camera motion. In practice, you want a lot more than 8 (typically 150-ish) for a robust and accurate solution. You requested to solve the range [7.0, 1000.0] and there were only 2 tracks in common between frames 7.0 and 8.0.
Как можно исправить эту проблему?
Вот файл проекта: Ссылка на проект
