Официальное русское сообщество Ornatrix
May 10, 2019 - Ornatrix Maya v2.3.6 is out!
New: MoovPhysics Save/Load/Reset Parameter Sets
New: Alembic import into Baked Guides (WIP)
New: Mesh from Strands conform to surface option
Fixed: Render version of hair not rendering when just importing an Alembic file into Ornatrix
Fixed: Strand groups are not imported from Alembic files
May 25, 2019 - Ornatrix Maya v2.3.7 is out!
New: Pop up save file dialog in Animation Cache Node when no file name is selected during recording
New: Added an option to save HFG root data to an Alembic file
New: Added a "Conform to surface" option to Mesh from Strands
New: Added "Record Frame" button to AnimationCacheNode
New: Added viewport preview % to Animation Cache node
New: Added an option to Animation Cache node to record render version of the hairs
New: Added Hair or Guides option for Alembic import
New: Add texture atlas generation to Scatter operator
Fixed: Unable to access any edit mode in Edit Guides with no input strands
Fixed: PropagationOperator: Incorrect values on Distribution Multiplier attribute
Fixed: Crash when Attaching Roots and moving time slider
Fixed: Brush size relative to viewport is consistent on HiDPI displays
Fixed: Edit Guides changes strand shape rotation when only moving roots on surface
Fixed: Hair disappearing after toggling Hair from Guides on and off in some cases
Fixed: The shelf must not be focused when Ornatrix is loaded
Fixed: Octane 2018.1 doesn't render 1% hair in viewport
Fixed: Pressing "Clear Recorded Data" in Animation Cache node doesn't clear data in memory
Fixed: Moving root after shape changes can rotate the strand
Rush
Хочу спросить - не могу заставить ноду Dynamic работать. Move - работает . Maya 2018. Ornatrix 2.3.7
И ещё - при попытке вручную редактировать Strand они при отпускании манипулятора прыгают обратно. Вроде смотрел в уроках для старой версии - там так без проблем двигали...
PS: исправлено в обновлении
Vadim Jin
И ещё - при попытке вручную редактировать Strand они при отпускании манипулятора прыгают обратно. Вроде смотрел в уроках для старой версии - там так без проблем двигали... Посмотреть вложение 266320
Привет!Я тоже с этим столкнулся (( Если разобрался ,как бороться и в чем проблема поскажи плиз . Буду очень признателен
хз вроде последняя стоит(( думал мож че нажал . прост если soft selection включен вообще не двигаются .не то что назад не пружинят((
Обновитесь до новой версии и выключите Soft Selection (B). Если нужен софт, он там свой есть в настройках.
June 14, 2019 - Ornatrix Maya v2.3.8 is out!
New: Option in Clump node to respect hair parts
New: Added an option to Mesh from Strands to ignore hidden strands
New: Collapsing most of the sections when the Edit Guides Attribute Editor is loaded for the first time.
Fixed: Scatter flattens reference spiral
Fixed: ASCII .ma files can cause shape changes in created guides not to be applied
Fixed: Cannot delete strands when multiple EG are present in the stack
Fixed: ClumpNode: Unable to remove Clump Patterns from the list
Fixed: ScatterNode does not scatter the selected Referecen Strands
Fixed: Wrong Axis used after exporting to the Ornatrix Alembic
Fixed: ClumpNode: The hairs disappear when adding a Clump Pattern
Fixed: Hair not shown in viewport after toggling on and off sometimes
Fixed: Hair does not render on Maya 2019 with Redshift
Fixed: Clump node can produce incorrect results for flat patterns
July 1, 2019 - Ornatrix 3dsmax v6.2.1 is up!
New: Greatly improved barycentric interpolation (To enable, select option other than "Distribution Mesh" in Hair From Guides)
New: OxGetStrandIds MXS function
New: Scatter modifier improvement
New: Specific 3dsmax version installers, reducing download size for updates
Fixed: Crash when planting a new guide after removing one
Fixed: Crash when adding OxClump to HairFromMeshStrips
Numerous internal refactorings
https://www.artstation.com/artwork/58oYJw
July 8, 2019 - Ornatrix Maya v2.3.9 is out!
New: Added an attribute to ScatterNode to make it only renderable
New: Baked Hair animation always uses frame 0 character pose to ground strands
Fixed: MeshFromStrandsNode: Artifacts on proxy meshes
Fixed: Grounded and bakes hair don't follow deforming distribution mesh
Fixed: All instances of Moov inherit the same Strand Group parameter
Fixed: Missing Plant Guides Tool button
Fixed: Edit guides Edit Mode buttons don't update correctly when multiple property windows are open
Fixed: Hair is not displayed until the viewport is rotated
Fixed: Hair looks different everytime is exported as .ass
July 17, 2019 - Ornatrix 3dsmax v6.2.2 is up!
New: Baked Hair object doesn't evaluate when 0% of hair are previewed in viewport
New: Hair From Guides uses displacement map's channel instead of distribution channel for displacement
Fixed: Crash when saving a scene with a Banked Hair object without any strands or channels
Fixed: Surface Displacement not working on Hair From Guides
Fixed: MeshFromStrands modifier: Artifacts on proxy meshes
Updated Chinese localization
Numerous internal changes
https://www.artstation.com/artwork/Z59z81
August 7, 2019 - Ornatrix 3dsmax v6.2.3 is up!
New: V-Ray standalone procedural groom export including a new .vrscene exporter and V-Ray standalone plugin
New: Option to load an Alembic file sequence in Strand Animation modifier using a pattern like "MyFile.###.abc"
New: Texture map can be specified in Generate Guide Data modifier
New: Adopt Shape option when planting roots
Fixed: Grounding deforms guides shapes
Fixed: Rotate operator does update viewport when using optimized mesh display
Fixed: Clumper crashes after manually deleting/creating clumps and assigning external guides
Fixed: Unable to comb hair generated with Hair from Mesh Strips
Fixed: Crash when combing ungrounded Hair from Mesh Strips hair
Fixed: Imported Alembic hair is not visible in the viewport when using optimized mesh
https://www.artstation.com/artwork/gJqG5P?fbclid=IwAR3OY_wuJ9ud2nWJW289GzQMOU0JB7Bpf3DLNM0vgGp2Z8tiwAZtCIJBHas
August 8, 2019 - Ornatrix Maya v2.4.1 is out!
New: Option to set width by absolute strand length
Fixed: EditGuides: Plant Guides tool gizmo is not accurate
Fixed: MeshFromStrands: Crash when adding a proxy mesh
Fixed: Unable to add Hair From Mesh Strip operator sometimes
Fixed: Selecting Grab brush takes you out of Brush Edit mode
Fixed: Crash when turning on Elastic Mode parameter with the Grab brush
Fixed: The hair object is loaded with wrong transformation values
Fixed: MultiplierNode: Artifacts on resulting guides
Fixed: Curl Operator: Slow performance when applied to propagated hairs
Fixed: Brush cursor not visible when Edit Mode is set using a MEL command
Fixed: Hair guides planted and brushed on Mac OSX don't display correctly in Windows
Использование нескольких контрольных точек для редактирования волос или направляющих обеспечивает точный контроль над вашими волосами. Установите количество контрольных точек на прядь и измените их, как будто вы редактируете сетку.
Просто еще один способ, которым Ornatrix позволяет с легкостью моделировать любую прическу.
Несколько новых уроков по Ornatrix c канала RaveeCG.
Урок про экспорт и render - Ornatrix .vrscene в V-ray GPU Standalone.
August 25, 2019 - Ornatrix 3dsmax v6.2.4 is up!
(yes)New: Animation Cache modifier loads Alembic sequence files on demand per frame (not whole sequence at once)
New: Added options (export, time, etc.) dialog to .vrscene export
New: Renamed Ox Strand Animation to Ox Animation Cache
New: Added support for per-vertex strand rotations
New: Added twist option to Strand Rotate modifier
New: Added a Lengthener option to scale width values
New: Added an option to set width by absolute strand length in Change Width modifier
New: Grooms and curve presets saved in 3dsmax can now be used in Maya and C4D
Fixed: Assertion/crash when serializing a stack with disabled/unsupported modifiers
Fixed: Assertion when rendering with Corona
Fixed: Mesh From Strands: ScatterMap doesn't work
Fixed: Time offset in Animation Cache modifier doesn't do anything
Fixed: Baked Hair object doesn't appear in viewports right away after being imported
Fixed: Baked Hair Object grounding doesn't work properly with non-identity distribution mesh transforms
Fixed: Edit Guides wrong scaling with multiple control points
September 10, 2019 - Ornatrix 3dsmax v6.2.5 is up!
New: Add root-to-tip curve for Edit Guides control point influence
New: Alembic export and Animation Cache modifier support ### in file names for exporting sequences
New: Using per-primitive Alembic properties to store strand and vertex attributes
Fixed: Scale Widths option crashes when input strands don't have width information
Fixed: The distribution mesh is not animated in the Moov simulation.
Fixed: Edit Guides control point rotation does not behave intuitively
Fixed: Edit Guides: wrong local pivot with multiple control points
Fixed: Roots are re-generated when the distribution mesh is deformed with Even and Random distributions
Fixed: Crash when scrolling the animation bar with Moov on the modifier stack
Fixed: Propagated strands can produce incorrect coordinates due to changing vertex space with invalid secondary transforms
Fixed: Mesh from Strands Conform feature not working
Fixed: Hair from Mesh Strips can freeze or crash with incorrect input meshes
Друзья, я прикрываю "лавочку". Просто физически нет времени и успеваю только поддерживать официальную группу в ВК. Так что если интересны новости, хотите пообщаться с однодумцами и так далее, задать вопрос например - вот ссылка
