Официальное русское сообщество Ornatrix
October, 31, 2018 - Ornatrix Maya v.2.2.4 is out!
New: Create a Strand Group option for the generated strands in Multiplier operator
New: Preserve strand length option in Multiplier operator
New: Propagated strands can be twisted in opposite direction
New: Propagate operator fanning can be defined with negative ramp values, allowing it to fan in both directions
New: Clumping works on hairs without surface dependency, such as on Hair from Mesh Strips and Baked Hair
New: Scatter operator option to preserve reference strand proportions
New: Scatter operator option to use reference strand widths
New: Generate Strand Data can write to hair texture coordinates
New: Multi-threaded Gravity operator
New: Elastic options for Move/Rotate/Scale/Grab brushes (WIP)
Fixed: Unable to paint Guide Roots in Per-Vertex Channels
Fixed: Per-Vertex channel colors are not shown in the viewport
Fixed: Gravity bends tips even at 0 force amount
Fixed: Moov physics crashes when applied on top of Hair from Mesh Strips
Fixed: Hair appearance not always consistent after rendering
Fixed: "Assign Value" command for strand data channels in Edit Guides does not work with Per-Vertex channels
Fixed: Symmetry operator doesn't copy all texture channels
Fixed: Edit Guides Preserve Strand Length does not work well with elastic brushes
Fixed: NormalizeStrands assert failed due nans
Fixed: Using "Guide Proximity" option in Hair From Guides node results in incorrect texture coordinates
Fixed: Loading .abc file in Animation node does not correctly animate hairs when less than 100% are previewed in viewport
Fixed: Detail node doesn't set the resulting hair texture coordinates
Fixed: Curling node texture coordinates don't work with maps
November 13, 2018 - Ornatrix 3dsmax v6.0.19 BETA is up!
New: Added "Set Absolute Length" option to Length modifier
New: Added Preserve Original Strand option to Multiplier
New: Added Multiplier Target Strand Group parameter
Fixed: Moov crashes with 3ds Max
Fixed: VRay IPR crashes when scrubbing an animated scene with deforming hair objects containing Edit Guides
Fixed: Animation modifier fails to record non-animated objects
Fixed: GenerateGuideData modifier produces incorrect indices when writing to Texture Coordinates
Fixed: Loading .abc file in Animation modifier does not correctly animate hairs when less than 100% are previewed in viewport
Fixed: Clump region texture map can have hairs jumping from one to another
Fixed: Texture coords. disappear when assigning a strand group in Detail Node
November, 16, 2018 - Ornatrix Maya v.2.2.5 is out!
New: Hiding hairs with Edit Guides works
New: Control the Amount parameter in Edit Guides using a Ramp Curve
New: Ability to control Edit Guides Amount with a texture map
New: Multiplier node: Added an option to keep the source strand instact
Fixed: Crash when turning off HFG with guides which have uneven vertex count
Fixed: Assertion when GFM doesn't have a valid input mesh
Fixed: MeshFromStrands: Scatter Channel not working
Fixed: MeshFromStrands: Shader list disappear when switching to Edit Guides
Fixed: Deleting hairs using EG causes an exception
Fixed: EditGuides: Maya should go back to object selection mode when exiting Brush Edit Mode
Fixed: Multiplier node: The Preserve Strand Lengths option creates artifacs
Fixed: The Hair Shape is locked after running a first render with Arnold
Fixed: Moov node creates a different simulation when pressing Play vs dragging the timeline
Finished adding support for Maya's new parallel evaluation pipeline
Источник - https://www.artstation.com/artwork/gJ2z3x
Источник - https://www.artstation.com/artwork/L23wWr
Источник - https://www.artstation.com/artwork/lVxbno
Источник - https://www.artstation.com/artwork/XBnDyl
Источник - https://www.artstation.com/artwork/XBnx6w
November 28, 2018 - Ornatrix 3dsmax v6.0.20 BETA is up!
New: Adopt From Stack option in Edit Guides works with added/removed hairs
New: Clump operator works on propagated hair for feather clumping
Fixed: Strand groups parameter in Clump modifier doesn't work
Fixed: Resolve Collisions does not restore hair state when animated and using Soft method
Fixed: Exception when rendering Ornatrix hair with Arnold
Fixed: (HFG) Adding a distribution channel creates artifacts on the hair strands
Fixed: Fatal Error when adding the Clump operator sometimes
Источник - https://www.artstation.com/artwork/OymDK8
Источник - https://www.artstation.com/artwork/0X3Dwe
Источник - https://www.artstation.com/artwork/58B911
Источник - https://www.artstation.com/artwork/3oqPaJ
Все работа с волосами/шерстью - сделана в Ornatrix 3dsmax
Новая версия и новый тутор.
December, 3, 2018 - Ornatrix Maya v2.2.6 is out!
New: Clump node works on propagated hair for feather clumping
New: Added hair isolation support to BakedHairShape
Fixed: Crash when deleting Edit Guides node
Fixed: Surface Comb: Slow performance when adding Sinks
Fixed: Frizz Operator: Different results on mirrored strands
Fixed: Alembic export with motion vectors can lead to a crash
Fixed: Surface Comb: Assertion when trying to edit mirrored sinks
Fixed: HFG: Adding a distribution channel creates artifacts on the hair strands
Fixed: Isolation tool does not work with Guides As Hairs
Fixed: Lack of precision when using Edit Guides plant tool, creating sinks, and partings
Fixed: EditGuides: Undoing Move roots changes the strands shape when some guides have been previously deleted
Fixed: Turning create strand groups option on/off in HFMS doesn't have immediate effect
Fixed: MeshFromStrands: Scatter Multipler maps breaks when deleting guides
Fixed: HairFromGuides: Weird bug with Guide as Hair view in viewport
Fixed: Isolation tool in BakedHair node is not working
Источник - https://www.artstation.com/artwork/VdyeBn
Источник - https://www.artstation.com/artwork/qAQQwn
Источник - https://www.artstation.com/artwork/XB1gzD
December 16, 2018 - Ornatrix 3dsmax v6.0.21 BETA is up!
New: Edit Guides can hide hair
New: Moov physics visualization in viewport
New: Minor compacting and reorg of Edit Guides panels
New: HairFromGuides Modifier hair isolation
WIP: Initial controls for elastic brush and control points support in Edit Guides
Fixed: MoovPhysics: External Collisions not working
Fixed: Switching to Edit Guides modify panel is very slow
Fixed: Edit Guides: Only non-soft selected Control Points should determine where transform gizmo is located
Fixed: Multiplier maps don't work with ChangeWidth operator
Fixed: Unable to invert multiplier values
Fixed: Incorrect Hair from Guides interpolation and guide type icons
December, 22, 2018 - Ornatrix Maya v2.2.7 is out!
New: Added an option to blend curves planted with Edit Guides "Import Multiple..." option with original curve positions
New: Added new Hair from Guides guide selection icons
New: Edit Guides soft selection
New: Surface Comb option to make the sinks symmetrical when created
New: Added a new Multiplier option to automatically ground the generated strands
New: Added Elastic options to Edit Guides Control Points mode
New: Added support to the Maya Transformation tools (Move, Rotate and Scale) in Root Mode. When option is on, hairs are rotated and scaled.
Fixed: Unable to make a copy of Edit Guides Attribute Editor window
Fixed: In Edit Guides strand mode transform gizmo is always at the origin (should be at center of selection)
Fixed: Moov: Channel selector controls do not respect group settings after UI update
Fixed: Control Points don't move correctly when editing with Elastic mode
Fixed: Control points don't update in viewport while dragging with Elastic option enabled
Fixed: Hair stack is reevaluated when mesh is connected to some unrelated to stack Ornatrix node
Fixed: Vray Next doesn't render Multiplier with 1% in Viewport IPR
Источник - https://www.artstation.com/artwork/Pm6Rq1
Источник - https://www.artstation.com/artwork/1nNrWL
Источник - https://www.artstation.com/artwork/3o1okA
Источник - https://www.artstation.com/artwork/58W3GA
January, 11, 2019 - Ornatrix Maya v2.2.8 is out
New: Added Strand Channel support to control the distribution of Propagator
New: Added Muiltiplier Map support to control the distribution of Propagator
New: VrayOxHairMaya renderer works with VRay 4 SDK
Fixed: Viewport freezes when collapsing Guides as Hairs
Fixed: Crash when collapsing the hair stack with RememberRootsPositions ON
Fixed: Plant Guide Tool not working when zooming out
Fixed: Generating hairs from selected polygons takes longer
Fixed: Oscillator causes strands to crumple when changing input strands topology
Fixed: Non-root transform tools don't behave correctly
Fixed: Surface Comb: Symmetry is located in the wrong place
Fixed: Clump Operator: Unable to pick External Guides
Источник - https://www.artstation.com/artwork/zAz61m
Источник - https://www.artstation.com/artwork/Bma8wA
Источник - https://www.artstation.com/artwork/L2Z8Xv
Источник - https://www.artstation.com/artwork/YaPRZY
Источник - https://www.artstation.com/artwork/rRXZG2
January, 27, 2019 - Ornatrix Maya v2.2.9 is out!
New: Optimized Mesh hair display, 4x viewport hair display speed up
New: Added strand group support to symmetry
New: Option to add detail based on strand length
New: Added Moov Physics curve control for particle mass and force fields
Fixed: Hair from mesh strips grow direction varies across platforms
Fixed: Symmetry node shuffles randomly the strands when using "Ignore Distance" or "Strand Groups"
Fixed: MoovPhysics: Particle mass parameters to have a more predictable effect on the simulation
Fixed: Ornatrix slows down when grooming on high resolution meshes
Fixed: HairFromMeshStrips: "Add Strip ID Channel" option adds too many channels and doesn't properly update the output
Fixed: HairFromMeshStrips: Strand Groups are not applied correctly
Fixed: Duplicated "About" window
Fixed: Brushes jitter in Surface mode when moving over surface
Fixed: Maya hangs when using Lasso Select to select Ornatrix guides
February 5, 2019 - Ornatrix 3dsmax v6.1.2 is up!
New: Added an option to add strand detail by length
New: Added a parameter to rotate clump patterns around the clump's stem
New: Added a way to match control and reference strands in Adopt External Guides modifier using distance
New: Added Chinese localization
New: Changed default root distribution to Even
Fixed: Installed Ornatrix toolbar does not contain new operators
Fixed: Moov strand stiffness different in different parts of the hair object
Fixed: Crash when using Round clumps option with manually selected clumps and a clump pattern
Fixed: "Use Sequential Ids" option doesn't produce sequential root ids with Vertex and Even distributions
Fixed: Moov: Cosserat model bug with root holder
Fixed: GenerateStrandData is wrong when using the "is inside object" generation method
Источник - https://www.artstation.com/artwork/oOxaWw
February 10, 2019 - Ornatrix Maya v2.3 is out!
New: Added support for Maya 2019
New: Added a parameter to rotate clump patterns around the stem
New: Added a way to match control and reference strands in Adopt External Guides node using distance
New: Option to add strand detail based on strand length
Fixed: No dense hair visible in viewport with Optimized Mesh setting
Fixed: Moov physics settings resets on reload when referenced
Fixed: Symmetry node doesn't preserve strand widths
Fixed: "Use Sequential Ids" option doesn't always produce sequential root ids
Fixed: Missing icon in AnimationCache node settings
Fixed: Animation Cache operator playback is out of sync when reloading a scene
Fixed: Some improvements to new circle area interpolation when it comes to curves meshes and irregular guide spacing
