Официальное русское сообщество Ornatrix
Ролик о создании мультика "Птичий дозор" от студии Luxx. Комманда использовала Ornatrix в своей работе.
И сам трейлер мультфильма.
August 12, 2018 - Ornatrix 3dsmax v6.0.13 BETA is up!
New: Capture and resetting of initial Moov simulation state
New: Simulation of Moov simulation rest state
New: Alembic Importer
New: Added browse button for Moov simulation scripts
New: Loaded file information to Strand Animation modifier
New: Added undo/redo support for strand grounding
New: Added option to mirror Edit Guides brushes in world space, by default it mirrors in object space
Fixed: Added Moov Python scripts to deployed 7z archive
Fixed: Alembic Baked Hair objects disappear when reloading the scene
Fixed: Moov simulation stops working after selecting the Moov modifier in the modifier stack
Fixed: Target object button is disabled in Generate Strand Data modifier when Is Inside Object method is used
Fixed: Disable external clumps and count options when changing clump generation method
Fixed: External Strands generation method doesn't work in Clump modifier
Fixed: Planting multiple guides in the same spot prevents edits to those guides
August, 16, 2018 - Ornatrix Maya v2.1.9 is out!
New: Added a pop up window to SurfaceComb node to import multiple Curved Sinks
New: Added an option to specify the up axis during Alembic export
New: Added an option to turn off face component selection in Hair from Guides and Guides from Mesh nodes
New: Added options to Curves from Strands operator to detach and copy individual output NURBS curves
Fixed: MergeNode keeps disconnected strands
Fixed: Mirror brush doesn't affect all brushed strands equally
Fixed: Planted guides don't inherit the strand group of the selected guide
Fixed: Image button controls in Attribute Editor can keep affecting attributes of previously selected nodes
Fixed: Merge node crashes Maya when deleting an item
Fixed: Crash when planting a new strand in EG without any previous strands present
Fixed: Unpredictable behavior of planted guides
Fixed: Messed up hair strands when loading more than one Alembic file into a single BakedHair node
Fixed: Edit Guides minimized rollouts do not remain minimized
Fixed: Propagator node randomness values don't randomize anything
Fixed: Propagator randomization adds to values instead of multiplying them
Fixed: Custom Point Count does not work when importing curves in Edit Guides
Fixed: Distribution icons in Attribute Editor can be absent due to duplicate control names
Fixed: Cannot use Edit Guides Attribute Editor interface when input strands are empty
Fixed: Maya crashes on Mac when rotating the viewport camera
Fixed: Alembic archives with multiple objects cannot be used to load hair animation
Fixed: Detail node smoothing does not work in some cases
Источник - https://www.artstation.com/artwork/O8Aaw
Источник - https://www.artstation.com/artwork/eOOq3
August 27, 2018 - Ornatrix 3dsmax v6.0.14 BETA is up!
New: Added Optimize Strands and Resample Strands options to Edit Guides
New: Hair preview in viewport is up to 3x faster
New: Much improved hair interpolation (WIP)
Fixed: Moov simulation behaves differently when dragging time or using real-time playback
Fixed: Modifying Resolve Collision parameters doesn't update the modifier's effect immediately
Fixed: Incorrect GUI name for Push Away from Surface modifier curve
Fixed: Memory consumption grows when dragging change width value (memory leak)
Fixed: Importing Alembic file with multiple animated strand object can produce incorrect results
Fixed: Strand Animation modifier is evaluated at every frame, regardless of whether there is animation or not
Fixed: Assertion Error when opening scenes made in previous builds of V6
Fixed: Curve editor diagram existing values can be mutated by dragging other values
Fixed: Detail modifier smoothing does not work in some cases
Fixed: Delete Clump(s) button in Clump node deletes all clumps regardless of the selection
Fixed: Symmetry operator doesn't copy strand groups
Fixed: Baked guides don't save strand groups
August, 30, 2018 - Ornatrix Maya v2.2 is out!
New: "Auto push away" option in Edit Guides works with control point editing and planting new guides
New: Edit Guides selects newly planted guide
New: Improved hair interpolation (WIP)
New: Toggling operator on/off toggles all selected operators
New: Added MoovPhysics parameter groups for simpler UI
Fixed: Cannot create strand groups for loaded BakedGuidesNode
Fixed: Strand groups are not saved in BakedGuidesNode
Fixed: Propagator distribution curve modifications don't update distribution
Fixed: Maya freezes when using the Mesh Strip Editing tool on Linux
Fixed: MoovPhysics CosseratElaston hair model excruciatingly slow
September 11, 2018 - Ornatrix 3dsmax v6.0.15 BETA is up!
New: Hair from Guides isolation sub-object mode (WIP)
New: Removed support for Max 2013 and earlier
Fixed: Bottom row of HFG distribution buttons can be selected when Remember Roots option is on
Fixed: Some modifiers don't return correct validity interval and are not re-evaluated when animated
Fixed: Guide clumping method does not work correctly
Fixed: Curling operator crashes with some configurations
Fixed: Max crashes when using the "Assign Channel" button in Ox Clump modifier
Fixed: Auto-push away from mesh not working in Edit Guides
Fixed: Incorrect texture coordinates in optimized mesh hair display
Fixed: Hair disappears from viewport while grooming
Fixed: Hair is not displayed in the viewport when using Performance display method
Fixed: Max crashes when changing the Viewport Hair Rendering Method to Mesh
Fixed: Clump Guides method don't match the Clump Editing Guides
Fixed: Unable to delete planted guides in Edit Guides in some scenes
Fixed: Broken Strand Groups when deleting hair strands
Fixed: Fixed: MoovPhysics CosseratElaston hair model very slow
September, 13, 2018 - Ornatrix Maya v2.2.1 is out!
New: Delete guides button is now present in all Edit Guides modes (includng Control Points and Brush)
New: Draw Strands mode in Edit Guides to draw new guides free-hand
New: Renderman 22 support
New: Arnold 3.1 support
Fixed: Unable to delete planted guides from older scenes
Fixed: Root Distribution parameters are not grayed out when using Remember Roots Positions
Fixed: Hair disappear when reloading the scene if a texture map is used on ChangeWidth multiplier and Remember Roots Positions is used in Hair rom Guides.
Fixed: Width information is not stored in the BakedHair node
Fixed: Alembic exporter and importer not setting UV coordinates correctly
September 27, 2018 - Ornatrix 3dsmax v6.0.16 BETA is up!
New: Arnold render support
New: Added an option to Ground Strands modifier to generate texture coordinates from surface
New: Parameter groups and separators in MoovPhysicsModifier UI
New: Added an option to switch between global and local strand segment orientations
Fixed: Hair clustering modifier produces randomly flying away hairs
Fixed: Strands in default group should not have red color
Fixed: Plant Guide tool: Planted guides don't inherit the strand group of the selected guide
Fixed: Select By Group option is not working
Fixed: Distorned imported splines in Edit Guides
Fixed: Ox Clump curves doesn't work in 3dsmax 2016
Fixed: Curler results and speed improvements
Fixed: Hair changes shape when modifying global segment orientation parameter and changing curl value
Fixed: Adopt External Guides modifier doesn't respect animation of control hair
Fixed: Hair from Guides modifier doesn't respect input guides animation
Fixed: Curling modifier can cause a crash in some scenes
Fixed: Optimize mesh view bug in 3ds max 2016
September, 29, 2018 - Ornatrix Maya v2.2.2 is out!
New: Added an option in Edit Guides to update on mouse release only
New: Added an option to Ground operator to generate texture coordinates from surface
New: Pressing F when in root mode of Edit Guides focuses view on the selected strand root(s)
New: Improvements to speed and output of Curl operator
Fixed: Crash when importing curves in Edit Guides
Fixed: Issue deleting clumps assigned to guides
Fixed: Unable to load Ornatrix in some cases
Fixed: Not all curves are imported when using Import Multiple in EG
Fixed: Edit Guides AETemplate disappear when switching modes.
Fixed: Ornatrix hair not supported in Arnold 5
Fixed: Sub-clumping does not work for higher clump count
Fixed: Error when clicking the Sinks Editting Tool button
Fixed: Randomly generated strand roots can contain patterns
Fixed: Legacy Hair clustering operator produces randomly flying away hairs
October 12, 2018 - Ornatrix 3dsmax v6.0.17 BETA is up!
New: Alembic can export velocity data with interval center and length parameters
New: Added an option to Clumping wth guides to only specify clump roots (and not the clump stem shapes)
New: Added entries to Ox global menu to create modifiers and objects
New: Updated Ox toolbar to contain new modifiers
Fixed: Oscillator modifier crashes when clicking channel select buttons
Fixed: Invert selection doesn't work
Fixed: Oscillator makes some guides jump when using Wind force
Fixed: Oscillator modifier stiffness map and channel aren't working
Fixed: Hair and guide roots aren't generated if UV coordinates are too small on a mesh
Fixed: Oscillator modifier doesn't respect animated forces
Fixed: Changing input per-strand data causes Hair from Guides to re-generate roots
Fixed: Sub-clump shape change if Hair from Guides viewport percentage is changed
Fixed: Corrupted string in macro recorder when editing clump amount value
Fixed: Clumper crash if there are 0 input hairs
Fixed: StrandAnimationModifier file path shouldn't be sticky
Fixed: Using External Clump Guides method crashes Clump Modifier
Fixed: GuidesFromShape on top of splines takes too long
Fixed: Arnold dll is not installed correctly
Fixed: Clump modifier "Add new index channel" option should not be sticky
Fixed: Max UI freezes when continually resizing modify panel with ramp controls in it
Fixed: Sub-clumping does not work for higher clump counts
October, 15, 2018 - Ornatrix Maya v2.2.3 is out!
New: Added Alembic velocity export with interval center and length parameters
New: Added an option to Clump node for guides to only specify clump roots and not the clump shape
New: Merge node supports HairShapes
New: HFG AE guideProximityDistance and guideFacesIterationCount are disabled if not used
New: ScatterNode uses the base strands widths to define the widths of scattered strands
Fixed: MEL error when duplicating EditGuides without rest of the stack
Fixed: Invert Selection in EG doesn't work
Fixed: Weaver: Unable to add curves to the Source Curves box
Fixed: Moved Propagator Selected Side to Selected Side Settings group
Fixed: Assertion when inserting a knot into an empty ramp diagram
Fixed: "externalClumpStrandsAssignButton was not found" warning when selecting clump external guides shape
Fixed: Propagation operator settings are not loaded from older scenes
Fixed: Edit Guides disappears from the operator stack when selecting the paint maps tool in HFG
Fixed: Hair shape won't render after diactivating MeshFromStrands
Fixed: Oscillator node doesn't respect animated forces
October 29, 2018 - Ornatrix 3dsmax v6.0.18 BETA is up!
New: Generate Guide Data has Target Data parameter allowing to alter various parts of hair data including texture coordinates
New: Implemented Generate Guide Data Is Inside Object option
New: Gravity operator is multi-threaded
New: Symmetry operator copies texture channels
Fixed: Detail modifier doesn't set the resulting hair texture coordinates
Fixed: Curling modifier texture coordinates don't work with maps
Fixed: Some unit tests fail on hi DPI monitors
Fixed: Max asserts when baking hair with Push Away from Surface modifier in the stack
Fixed: Mirrored sinks change on deforming mesh after a scene reload
Fixed: Hair roots shouldn't change on a deforming mesh during single frame render if 100% of hairs are previewed
Fixed: Changed Oscillator force multiplier to closer match Max forces behavior
Fixed: Wrong Hair UVs coordinates when using the "Use Guide Proximity" option
