Официальное русское сообщество Ornatrix
Ornatrix Maya v2.0.1 is up!
New: Even (Poisson) UV-based distribution of points in Hair from Guides and Guides from Mesh operators (https://vimeo.com/237350097)
New: Normalize Strands operator for normalizing hair flow and fixing intersections (WIP)
New: Clump and twist amount maps and channels
New: AnimationCache node has buttons to save and load .abc files
New: Planted Guides inherit the Strand Group of the selected guide if Strand Groups are present
Fixed: Strand group info embedded in hair lost when changing distribution type
Fixed: Crash when brushing in Edit Guides node added on top of hair
Fixed: No hair is generated when using 1 incoming guide and 1 guide interpolation
Fixed: Braid guides icon missing from Shelf
Fixed: Ornatrix Maya v2 BETA can not be loaded in Maya 2015
Fixed: Hair with polar interpolation randomly changes rotation on deforming meshes if it is parallel to the surface normal
Fixed: Jumping guides when adding a collision mesh in Dynamics node
Fixed: Sporadic glitches when using Is Inside Mesh test in Generate Guide Data node
Fixed: Hair artifacts when using Interpolation Weight in combination with Segment Interpolation
Fixed: Planting guides does not copy the transformation from one guide to another correctly
October 23, 2017 - Ornatrix 3dsmax v5.2.5
New: Added multi-threading to Surface Comb
New: Switched propagation modifier to use new Qt curve diagrams in Max 2017 and above
New: Updated OX Edit Guides graphs to new graphs with presets
New: Surface Comb bending now has value range allowing to bend backwards and more forward
New: Planted Guides should inherit the Strand Group of the selected guide if Strand Groups are present
Fixed: Ornatrix toolbar not showing up in all workspaces in 3dsMax 2018
Fixed: Max crashes when importing splines into EG
Fixed: Sporadic problems with Is Inside Mesh test in Generate Guide Data modifier
он говорит, что кайфует 12 часов в день за деньги. Хотел бы и я таким расстройством психики болеть, получаешь кучу дофамина и за это еще и платят
Я чет не уследил, он здесь деньги
п-т как дышит
November 6, 2017 - Ornatrix Maya v1.3.3 is up!
This is a maintenance release, fixing some critical bugs:
New: Reduced memory usage immediately after evaluating render-time hair (improvement for heavy scenes)
Fixed: Strand groups and other channel data not being saved/reloaded with the scene
Fixed: Broken guides after reloading the scene
Fixed: Errors and crash when turning on HairFromGuides node in some scenes
Fixed: Stack Overflow exception when trying to render many hairs using mayabatch.exe
Fixed: Hair from Guides parting maps are not working
Fixed: Detached Surface Comb sinks disappear when reopening the scene
