Не устанавливается 3ds max
Дмитрий Соловов (Whitecolor)
2014/11/22:22:01:14DmitryDMITRY-ПК=== Setup started on DMITRY-ПК by Dmitry ===
2014/11/22:22:01:14DmitryDMITRY-ПКLaunch
2014/11/22:22:01:53DmitryDMITRY-ПК=== Setup ended ===
2014/11/22:22:01:20DmitryDMITRY-ПК=== Setup started on DMITRY-ПК by Dmitry ===
2014/11/22:22:01:20DmitryDMITRY-ПКLaunch
2014/11/22:22:02:09DmitryDMITRY-ПКPageOpenLaunchDialog
2014/11/22:22:02:43DmitryDMITRY-ПКPageOpenLicenseDialog
2014/11/22:22:03:03DmitryDMITRY-ПКPageOpenLaunchDialog
2014/11/22:22:03:08DmitryDMITRY-ПКPageOpenLicenseDialog
2014/11/22:22:03:11DmitryDMITRY-ПКPageOpenProductInfoDialog
2014/11/22:22:03:18DmitryDMITRY-ПКPageOpenProductSelectionDialog2
2014/11/22:22:03:21DmitryDMITRY-ПКPageOpenFullProgressDialog
2014/11/22:22:03:21DmitryDMITRY-ПКInstalling Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dmitry\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/11/22:22:05:25DmitryDMITRY-ПКInstallMicrosoft Visual C++ 2005 Redistributable (x86)FailedInstallation aborted, Result=1603
2014/11/22:22:05:27DmitryDMITRY-ПКPageOpenInstallCompleteDialog
2014/11/22:22:06:33DmitryDMITRY-ПК=== Setup ended ===
2014/11/22:22:22:25DmitryDMITRY-ПК=== Setup started on DMITRY-ПК by Dmitry ===
2014/11/22:22:22:25DmitryDMITRY-ПКLaunch
2014/11/22:22:22:54DmitryDMITRY-ПК=== Setup ended ===
2014/11/22:22:22:31DmitryDMITRY-ПК=== Setup started on DMITRY-ПК by Dmitry ===
2014/11/22:22:22:31DmitryDMITRY-ПКLaunch
2014/11/22:22:22:56DmitryDMITRY-ПКPageOpenLaunchDialog
2014/11/22:22:23:53DmitryDMITRY-ПКPageOpenLicenseDialog
2014/11/22:22:24:27DmitryDMITRY-ПКPageOpenProductInfoDialog
2014/11/22:22:24:45DmitryDMITRY-ПКPageOpenProductSelectionDialog2
2014/11/22:22:24:48DmitryDMITRY-ПКPageOpenFullProgressDialog
2014/11/22:22:24:49DmitryDMITRY-ПКInstalling Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dmitry\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/11/22:22:25:52DmitryDMITRY-ПКInstallMicrosoft Visual C++ 2005 Redistributable (x86)FailedInstallation aborted, Result=1603
maiden666
С++ не устанавливается
Слышал такое решение проблемы - инсталлятор сначала распаковывается в некую временную папку, потом запускается пакетный файл, который и выводит на экран окно установки. Необходимо её прервать, найти ту самую временную папку, и запустить просто 3Ds Max.exe, наплевав на Си и прочую фигню
maiden666
я и написал вариант
Отыщи ту самую временную папку, Макс с сайта компании всегда перед установкой спрашивает, куда распаковаться, по умолчанию в C:/ Autodesk, как себя ведут торрентовские пакеты, я не помню, но скорее всего в AppData-> Temp, можно попытаться вообще просто ПКМ по файлу инсталятора, и попытаться просмотреть содержимое архиватором, и вытянуть нужное из архива, 7-Zip позволяет делать такие вещи
Не помогает, такая же ошибка
2014/11/25:00:39:39DmitryDMITRY-ПК=== Setup started on DMITRY-ПК by Dmitry ===
2014/11/25:00:39:39DmitryDMITRY-ПКLaunch
2014/11/25:00:39:49DmitryDMITRY-ПКPageOpenLaunchDialog
2014/11/25:00:39:52DmitryDMITRY-ПКPageOpenLicenseDialog
2014/11/25:00:39:55DmitryDMITRY-ПКPageOpenProductInfoDialog
2014/11/25:00:40:37DmitryDMITRY-ПКPageOpenProductSelectionDialog2
2014/11/25:00:41:38DmitryDMITRY-ПКPageOpenFullProgressDialog
2014/11/25:00:41:38DmitryDMITRY-ПКInstalling Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dmitry\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/11/25:00:42:11DmitryDMITRY-ПКInstallMicrosoft Visual C++ 2005 Redistributable (x86)FailedInstallation aborted, Result=1603
maiden666
я всё ж таки предлагаю воспользоваться моим способом, то есть запустить установку просто Макса, без всяких Си, если нет, то http://knowledge.autodesk.com/suppo...during-installation-of-Autodesk-software.html
особо обрати внимание на последний пункт, про работу с реестром
А где отключается установка C++?
maiden666
да сколько ж можно по кругу ходить, я ведь описал процесс в постах 3 и 5
У меня сейчас Максовского установщика нет, но вот на примере другой проги, я открыл её установщик архиватором, там внизу ты видишь папки vcred, это и есть Си, где-то там есть и файл .ехе, запускающий установку программы
Распакуй папку, и запусти его
Если и так не получится избежать установки ненужного, можно отыскать файл, который будет зваться как-то вроде Install.cfg, в которм указаны пути ко всем компонентам, которые будут
устанавливаться, и удалить те строчки, которые ведут к ненужным тебе, Си, например, я делал так в другой ситуации
ИвТоп
Не мог установить 3D Макс - перелазил всё что мог ! Кучу всего перепробовал !
Важно - ПОСМОТРЕЛ какая ошибка - вроде зафейлилась установка на СС++
1 Удалил ВСЕ Microsoft Visual C++ подчистую !
2 Установил последний Microsoft Visual C++ (с офиц сайта)
3 Скачал и установил с офиц сайта Макс ! (щас на 3 года можно поставить free)
при установке он мне сам дописал недостающие Microsoft Visual C++
ЗАРАБОТАЛО !
