Программа называется ReelMotion. Вот её описание:
¦ ReelMotion is a realtime simulator that uses physics and collision ¦
¦ detection to create realistic animations of objects and vehicles ¦
¦ including cars, aircraft, motorcycles, helicopters and nearly any rigid ¦
¦ body object. ¦
¦ The ReelMotion Simulator is a standalone application that you can use ¦
¦ with any animation program that supports the Biovision or Acclaim motion ¦
¦ capture file formats. The ReelMotion plug-ins for Electric Image, Cinema ¦
¦ 4D XL, LightWave, Maya and 3D Studio MAX make it easy to transfer data ¦
¦ between ReelMotion and the animation software. Plug-ins for several ¦
¦ other animation programs are under development. ¦
¦ In addition to the animation tool described below, the ReelMotion ¦
¦ physics engine can be used in games, movie rides and other custom ¦
¦ projects. For more information about these, please visit the APPS page ¦
¦ when you have finished. ¦
¦ What Does ReelMotion Allow You To Do? ¦
¦ Drive it. If you've ever tried to animate a car, you know how hard it ¦
¦ can be. With so many elements like tire rotation, strut position and ¦
¦ sway, it's nearly impossible to make it look real. It could take weeks ¦
¦ to create 20 seconds of animation. Wouldn't it be nice to just drive the ¦
¦ car? ReelMotion allows you to do exactly that. 20 seconds of animation ¦
¦ takes 20 seconds to make. Use a mouse or joystick to drive or fly your ¦
¦ vehicle in realtime - just like a game or flight simulator. ReelMotion ¦
¦ creates the motion data for your animation program. ¦
¦ Fly it. Configure nearly any fixed wing aircraft or helicopter in ¦
¦ ReelMotion. Then fly it with ease using the advanced autopilot. ¦
¦ ReelMotion's flight models will make your aircraft animations look ¦
¦ absolutely real. Climb it. In the real world, vehicles drive on more ¦
¦ than flat pavement. Almost every surface has cracks and bumps. ¦
¦ ReelMotion allows you to import any terrain and then climb all over it. ¦
¦ It automatically detects the surface and makes the car and suspension ¦
¦ react accordingly. The nightmare of positioning tires frame by frame is ¦
¦ gone. ¦
¦ Shoot it. Film the action using your choice of camera: TV Track, Chase, ¦
¦ External, you name it. Pick the object to track and ReelMotion will do ¦
¦ the camera work. Add jitter and bounce for realistic motion or increase ¦
¦ the lag if it's tracking too quickly. Use the mouse to get behind the ¦
¦ camera - you have as much manual control as you'd like. Record a ¦
¦ simulation, replay it, and save as many camera takes as you need. From ¦
¦ 8mm to IMAX, you can be sure to capture all of the action. ReelMotion ¦
¦ will be your camera man so you can have fun being director. ¦
¦ Roll it. Import a proxy of your vehicle and ReelMotion will let more ¦
¦ than your tires touch the ground. Take a turn too fast and you'll roll ¦
¦ onto your roof. Touch a wing tip when landing and your airplane will ¦
¦ flip. Your proxy doesn't have to look like a car. Bring in a bottle, a ¦
¦ ball or a can. The physics will work regardless of the shape. The proxy ¦
¦ is also used for collision detection. Have fun throwing things around. ¦
¦ Bounce it. With control over the friction and collision characteristics ¦
¦ of your object, you dictate the way it behaves. A plastic bottle will ¦
¦ bounce off the floor. A half-deflated soccer ball will thud against the ¦
¦ ground. Adjust your object's settings until it rolls, bounces and slides ¦
¦ the way you want. ¦
Хотя и вручную всё это можно воспроизвести... правда если анимации действительно много, это может занять много времени.
Удачи.
