Вышел CorelDRAW 11 Service Pack 1 for Windows
- Автор темы Edward Aksenovsky
CorelDRAW Graphics Suite 11
Service Pack 1
README File
Contents
Suite-Wide Updates
Globalization
Workspace Management
Stability
Filters
Updates to CorelDRAW 11
Customization
Symbols
Tools
Document and Object Controls
Text Engine
Updates to Corel R.A.V.E. 2
Importing
Updates to Corel PHOTO-PAINT 11
Tools
Rollovers
Web Export and Web Image Optimizer
Stability
Suite-wide Updates
Globalization (Non-native operating system issues)
Service Pack 1 contains improvements to globalization support within text input for Latin- and Asian-language operating systems.
Service Pack 1 has addressed issues with workspace management in CorelDRAW Graphics Suite 11.
Stability
Service Pack 1 contains improvements to the overall stability of the CorelDRAW Graphics Suite 11 programs.
Service Pack 1 has also corrected a stability issue that occurred while copying a CorelDRAW (CDR), Corel R.A.V.E. (CLK), or Corel PHOTO-PAINT (CPT) file from Windows Explorer to an Iomega ZIP drive.
Filters
Publish to PDF Issues Corrected in Service Pack 1
Embedding a Proportional Japanese font in a PDF file no longer results in an invalid PDF file.
A font substitution no longer takes place when embedding the non-proportional Mincho Japanese font in a PDF file.
Fixed extended characters now appear correctly in PDF files.
SVG Export Issues Corrected in Service Pack 1
Fixed Japanese characters now export correctly to Scalable Vector Graphics (SVG) format.
TIFF Export Issues Corrected in Service Pack 1
The transparent background option is now available when exporting to TIFF format.
PNG Export Issues Corrected in Service Pack 1
Transparent backgrounds now export correctly to Portable Network Graphics (PNG) format.
CPT Export Issues Corrected in Service Pack 1
Text layers are no longer truncated or omitted when exporting files from CorelDRAW 11 to Corel PHOTO-PAINT (CPT) format.
Adobe Photoshop Export Issues Corrected in Service Pack 1
Layers and lenses now export correctly to Adobe Photoshop (PSD) format.
Text layers are no longer truncated or omitted when exporting files from CorelDRAW 11 to PSD format.
GIF Export Issues Corrected in Service Pack 1
In Corel PHOTO-PAINT 11, masks defining transparency information are no longer lost when exporting or saving to GIF format.
Customization
Service Pack 1 has addressed several issues with customizing workspaces in CorelDRAW 11.
You will no longer encounter instabilities while changing between workspaces.
The length of the path to a saved workspace location can now be longer than 128 characters; changes to the workspace or to the program will be saved as expected with longer paths.
(Mac OS) Palettes no longer become inaccessible when customizing the workspace.
Symbols
You can now copy and paste symbols from one symbol library to another. You can also create a symbol from a rotating vector extrude. In addition, Service Pack 1
has corrected a stability issue that occurred while editing symbols containing rollovers.
Tools
Double-clicking a node's control points with the Pen tool no longer deletes the node.
Double-clicking the last node in a curve with the Bйzier tool now creates the next segment as a line; it is no longer created as a separate Bйzier object.
The Eraser tool settings are now retained as expected, and nib controls behave as expected with pressure-sensitive graphics tablet pens.
Refresh issues while using the Pen tool have been resolved.
The Document information dialog box is now accessible for files containing multiple rollovers.
The snapping behavior of the 3 point rectangle, 3 point ellipse, and Polyline tools now respects the options specified in the Snap to objects setup dialog box and is consistent with the snapping behavior of the other CorelDRAW 11 tools. In addition, Service Pack 1 corrects precision errors that were occurring when snapping objects to guidelines.
Text Engine
The font list now scrolls correctly when using a left-handed mouse configuration.
(Mac OS) The Panose font matching dialog box no longer appears when opening CorelDRAW (CDR) files that contain embedded fonts.
Importing
You can now use the Enter key while importing to place the imported file on the stage.
Tools
The Crop tool no longer causes a single-pixel shift in images being cropped.
Functionality issues with the brushes and their associated controls have been resolved.
Rollovers
Service Pack 1 includes improved rollover handling for both Windows and the Mac OS.
Service Pack 1 has addressed issues with the Export for Web feature and the Web image optimizer.
Stability
Service Pack 1 has corrected a stability issue when creating very small pixel images.
Service Pack 1
README File
Contents
Suite-Wide Updates
Globalization
Stability
Filters
Customization
Symbols
Tools
Text Engine
Importing
Tools
Rollovers
Stability
Suite-wide Updates
Stability
Filters
Customization
Symbols
Tools
Text Engine
Importing
Tools
Rollovers
Stability
Да нет, это не только тень. Тень — это всего-навсего частный случай растра с прозрачностью и/или растушёванными краями.
Оверпринты ты заметил? Вернее, их отсутвие при экспорте в TIFF. И как же без них?
Констуктивного по ДПП в Кореле можно написать очень не много, поскольку куда не кинь, всюду у него не слава богу. Самое конструктивное — переносить кореловские макеты в AI и готовить там.
> В Кореле - определенно, гибкость и удобство трансформаций.
Йо-ой-ой. Сколько раз мы это уже слышали. Трансформируй-ка мне как-нибудь, кроме мастабирования и поворота, «дырку» в букве «О» переведённой в кривые. А потом сдвинь куда-нибудь ОДНОВРЕМЕННО с другим объектом (про то, чтобы он был текстовым уже молчу).
И на хрена маяться, готовя «основу» в Кореле, когда перетащить всё в AI и переделать отнимает порой больше времени, чем нарисовать всё в AI с нуля?
> давай про вектора. С ними в кореле что не так?
На вскидку — невыводящиеся, роняющие или вещающие любой RIP вектора, полученные в результате кореловского эффекта Сontour.
> контексте названия темы, твои рекомендации по поводу AI очень "актуальные"...
Да, актуальные. Потому, с выходом SP1 для CDR11 мы имеем ещё одно подтверждение тезиса «Горбатого могила исправит», что выше уже сказано.
да контур в кореле не фонтан, согласен.
и считается медленно когда сепарэйтишь и глючит на многих шрифтах... вот думаю в них как раз и дело. С той десяткой шрифтов, которой пользуюсь я, контур работает нормально. И ниразу еще проблем небыло с выводом газеты.
Но и в АИ работа с контуром меня не совсем устраевает, хотя конечно глобальных нареканий к его работе нет, ну если только при работе с нескурвленным текстом иногда что то чудит,, но это могу и я что то не так делать ) Например пытатся контур под буквы поместить
А вообще самые приятные воспоминания о работе с контуром у меня связанны с программами заточенными под наружную графику. Вот где программеры чудеса творят.
Ладно, что еще кроме контура?
да уж в кореле после эффекта преобразования контура в объект бывают "колбасные" штуки Рычаги векторные забрасывает за пределы громадного кореловского листа. Если объект, к которому применяется №Контор" сложный , и как говорится "с дыркой" внутри, то получившийся объект ОБЯЗАТЕЛЬНО нужно проверить и почистить. Иначе... Ну вы и сами знаете, как плохо РИПам бывает
