В чем разница?
PJ
А существенна ли разница между версиями 2. 03, 02 и 01?
Какие отличия? Стоит ли ее качать если есть 01?
PJ
Искал у них на сайте более подробную инфу( что в 03 исправлено и добавлено), что то не нашел. Может кто даст ссылочку.
List of features, bug fixes and performance enhancements in Xsi v2.0.1
Animation
66125 Need a function in IK to set kine states to skeletal object
73489 Ability to set defaults for Animation Editor Preference
74821 AXSI-time control loading its own frame rate causes problem when the latter different from scene frame rate.
74895 Model pop during playback (model is animated using mixer i.e. with one frame long clips and standard transition)
74900 Refresh problem when moving locked in X Curve -> Keys don't follow the curve.
74948 XSI-Crash-with replace shape ( added edge )-topology edits not supported. Need error not a crash.
75008 ATrim after not working sometimes...
75012 XSI-Problems with shape animation-bad twisting/flipping of normals.
75131 DND a source (should be on a folder) from another model on a track -> Two sources created.
75142 XSI- link with orientation crash-Client script
75301 Keyframe will be deleted when adding a new key (only happens with specific framerate)
75328 No longer able to delete instantiated shape clips
75371 Explode compound clip then undo assert and if you do few times will crash XSI.
75383 CRASH when leaving the the cursor over animation divot in the mixer (while playing back in loop)
75423 Copy\Paste multi-selected keys from one object to another no longer working (single copy\paste is OK)
Converters/Import/Export
74967 DotXSI - Import incomplete files make XSI crash
75088 XSI-Crash-Import SI3D-Customer 3x scene
75112 W2K Japanese OS - SI3D Loader -importing this scene crashes XSI
75266 Regression -DotXSI chain not imported correctly when branch selected prior to Export
75276 DotXSI Import - Materials not Imported with this scene
75298 DotXSI Import resets the framerate to 29.97 ,even if both the dotXSI file and scene are set to 24 FPS
75316 Dotxsi Import rotates parts of character 180 degrees
75325 DotXSI-Import - crash when importing this dot XSI file
75370 Crash loading scene from 1.5.3 with explicit UV
75469 DotXSI : Assert importing IK and envelope
Data Management
72770 IRIX LINUX | Saving first preset takes a long time .... App looks like its frozen
74153 Assert when re-doing the deletion of an object | C3DTaskHandler.cpp
74693 Implement Channel manager on Linux
74956 Texture shader nodes, should have their own namespace (old scenes)
75223 Render: Options: relative Image filename path isn't accurate.
75292 Ref Models - persistence - scaling animation lost on referenced model when scene reopened
75311 Asserts and CRASH : deleting specific scene
75378 Assert (C3DActiveData_Cnx.cpp): Open a scene then File\New.
Games
75480 No_Icon pic lost it's alpha channel.
General
73868 Information missing on the DuplicationOptions for "Copy Animation and Share Mixer Sources" and "Copy Animation and Copy Mixer Sources".
74877 XSI crashes using freeze followed by multiple undo's Client Script
74975 Cannot make Local properties on Clusters ['ERROR : "2003-PROP-SIMakeLocal - Interface not supported."]
74977 User is unable to delete Inherited Texture map properties on a cluster
75144 Hair: Crash when persisting scenes
75289 Assert and crash upon "delete all" with specific scene
75312 Unexpected failure when trying to delete an object in a specific scene.
75489 CRASH in duplicate hierarchy with branch operator
Modeling
73554 Hair: BRACES: Assert when switching to selection mode (.... while doing some Shape deform animation)
73917 Extrude along Curve with Polygon
74156 Duplicate Using Geometry Approx- flips model around in Z axis
74229 CRASH - Do Surface\Loft with more than one identical curve that are at the same position.
74751 Corrupt scene - FreezeObj causes XSI to freeze or crash
74858 Deformer Name sorting should be Case Insensitive
74882 Duplicate Using Geometry Approx fails on customers model
74906 CRASH when applying extend to curve
74950 Conflict in Weight Panel / Weight Editor Display of envelope after Cage Deform is added.
74963 Regression EPS file import yields incorrect results
75000 Extract from polygons should carry the hard-edge flag over to the new mesh
75039 CRASH: Deform->Cluster Center on itself crash (interactive only, not scripting)
75091 Client Scene has Problems with merge (poly mesh)
75113 Duplicate Using Geometry Approx will result in error message in script editor
75135 Linux : Loft doesn't work with boundaries
75222 Crash when selecting cluster in the Texture Editor
75381 Mirror weights not working on client scene
75455 CRASH: Copying and pasting a cluster from one object to another
75542 Weight panel : paint tool is not painting the Right colors on the envelope
75553 Mesh feature versioning can be corrupted, breaking all backcomp
75567 Preset: Regenerate preset for curve net to have Feature match OFF by default
Rendering
62924 Texture management logic must be moved out of SPCs
66058 PERFORMANCE: even if an object is hidden, XSI will still push it to mental ray, with the textures
73109 Running particular script twice asserts and Crashes XSI
73168 Rendering at resolution 1400, doesn't display on 1600x1200 screen
73992 Render Vertex Colors overwrite Alpha (add option in rendermap)
74107 Shader wizard should offer frame buffers options for output shaders
74185 Switch pass performance problem
74224 Object references don't work with NULLs - sib_lightning
74308 Ren/region/options help is missing a few FG options
74454 Xsibatch -prescript/-postscript using .vbs or .js files will simply hang
74657 HUGE memory buildups when switching Render Passes
75027 Invalid texture files are always reloaded upon xsi regain focus, it should attempt to load only once
75151 CRASH : drawing a render region in specific scene
75205 Crash if you select as an image a .vbs and render
75229 Render Pass renders Twice on loaded scenes with pre-post scripts
75524 No elliptical filtering in bump mapping
75526 RTS - Linux only : nvidia nodes crashed XSI
Scripting
45852 Support Python/PerlScript subroutines
75279 XSI freezes when running a script that execute a "FreezeObj" command
SDK
67120 Setting a scripted Op on a scripted Op variable makes the scripted Op (1rst one) not working.
67647 OM review functionality/documentation related to type checking
69418 Shader wizard doesn't create project directory for you
73585 UNIX : XSIApplication_OnKeyUp does not work
73833 OM: Custom commands not properly exposed to scripting
74207 OM: Kinematics.Local.Transform is just a copy of the object's kine pose (by design)
74215 WORKGROUPS : the file spdl.xsiindex is not properly cleaned when the master uninstalls an addon
74552 Shader wizard needs to generates a GUID
74636 .so installed in the "Other" section of an addon are not registred on UNIX like DLLs are on NT
74660 When packaging a custom command associated to a DLL, the DLL is not listed in the library section
74662 Custom Commands not working in workgroup
74688 WORKGROUP: shared plug-in still announced after unsetting workgroup ( xsi -w ).
74758 Show edges : Guids in show_edges.spdl should have values (and not be set to zeros)
74780 Xsi -i should have an option to install an addon at user location
75009 Assert (C3DScriptedOpHostEditable.cpp) when opening a scene with scripted Operators.
75215 ShapeClip.MappedItems return E_NOINTERFACE
75385 Add-On - missing "Realtime Shader" category
Simulation
74452 Need Particle Error Messages a) if not enough space to create a valid ptp at current frame and b) if ptp cannot be read at current frame (invalid/incomplete,permission,etc)
List of features, bug fixes and performance enhancements in Xsi v2.0.2
Animation
75317 "Merge to New Source" not working on Linux (OK on NT)
75707 Keep FCurve timing fixed (Fcurves scaled to compensate the framerate change) not working.
76129 IK effector transforms should always be exported in local
Compositing
75925 FX: Fxtree - when rendering to .AVI or .MOV, the images are highly compressed and look bad
Data management
75313 XSI is unable to properly save scenes, from a Mapped DFS network mount
75736 Data management: File-Open-cancel from Load scene window, causes XSI to crash.
76007 XSI -r -import doesn't or XSI -script toto-ignor.vbs doesn't work
76065 Forward cross-model reference of Instanced FCurves not supported
76475 Scene crash on load - Cage Deform corruption
76474 RefModel : Properties on referenced model are not saved anymore
77130 Lost of image clips: image clip are flagged "not used" even if shaders do use it
77018 Shape animation imports badly from SI3D
Documentation
76926 Documentation cd: Guides will open to cover pages of other areas (Links in the HTML documentation that point to other guides in the collection now work as long as you open the guides from the main menu pages)
77625 Documentation CD | Info page of PDF format | keeping the menu open directions refers to acrobat 4.05 (The instructions for how to use the Acrobat Reader has been updated)
77647 Documentation CD | Can't install Acrobat on Linux, DOS2Linux needs to be done (Acrobat Reader installer for Linux works without the user having to do a To_Unix on the files first)
Games
76193 RTS - image clips are not updated in realtime shaders
General
75812 With warning message: accepting to continue loading a scene from an unsupported version results in bad viewports
75813 No more warning message when you are trying to load a scene from a version no longer supported
Installation/Licensing
75960 SPM can not handle 64+ (spm connections) on windows platforms
76294 XSIbatch does not share -guilic
76830 License fall back when using xsibatch
77217 Incremental Setup : Unable to find the help file from script editor
77273 XSI 2.0.2 : New feature tour installation path is different from the shortcut path
77036 2D motion blur doesn't work under Linux. A file is missing
77399 SPM | Cloth token should be called on demand
77378 XSI Batch Package | XSI can not render advanced features with batch package
76678 SPM | Orphaned Licenses remain checked out on SPM server
78019 SPM communication socket protocol causes anti-tempering mechanisms to be enabled.
77192 MI_ADD_PLATFORM | need to recompile sibase so that MI_ADD is in sync with the Hair changes
Rendering
75781 Texture Editor - Heal doesn't work on simple example of topology edited cube
75987 XSI - view volume culling is disabled by default (regression)
75999 Need to expose Seam U and V when freezing texture projection
76230 Performance - OGLTexture2D always uploading the texture even if time has not changed
76866 Material and textures are missing when load the .emdl in a new XSI session
SDK
76035 XSI SDK: Command line option: xsi -script test-hQA_Batchscript.vbs not working
Simulation
75793 Hair: Rendered Hairs Jitter
75809 Simulation-Particles: XSI crashes after deleting multiple obstacle properties using script command.
75877 Scenes with a SoftBody applied to an open geometry will crash when rendered with "xsibatch -r".
76026 XSI-Bug with script used to apply 'object to particle' is missing statement to correctly ignore targets if tangency is not used.
76054 Hair: Crash Rendering Scene
75906 Crash reloading Scene if Hair Cache Files are inaccessible.
76836 Crash on multiple hair volumes
77019 Hair: Hair disappears if Obstacle Object deleted.
77229 Hairs appear/disappear in alpha channel
76283 Spherical artifacts between Hair Segments
75810 Hair: Transparency incorrectly dealing with shadows.
76018 Hair Renders Ambient/Specular components incorrectly.
77293 Help update for sib_hair shader
Viewing/Interaction
74259 XSI-inprecisions and usability issues with snapping
75744 XSI - OpenGL versions > 1.2 are treated as version 1.0 (performance issue)
77970 MAJOR slowdown between 2.0.2 rc2 and 2.0 when minimizing \ maximizing the application
List of features, bug fixes and performance enhancements in Xsi v2.0.3
Animation
76202 AE - Add a hotkey for set slopes to slope zero
79342 When a user deletes a key, the result is different from SI|3D.
79343 SI3D style slope appears longer in xsi than in SI3D
74145 Animation Mixer - audio is turned off when closing the window
78912 Export Action to ANI file, does not export slopes.
75875 AE - full SI3D style slopes (optional) support in XSI.
77342 Animation Mixer - when keyframes are edited in the Animation Editor, the keys are placed on incorrect frames
70289 AE - icons (and hotkeys) for quick access to the View menu choices (marked params, animated, selected)
78732 Delete marking set on one cube deletes it from another cube also
77888 Wrong result when doing "Zero slope lengh" whith SI 3DCurve style.
76647 Press the ? on the dopesheet PPG -> old screenshot (Clear button is missing)
78579 Corrupted Customer Scene - scene will not load
76345 The View menu 'interactive Zoom Tool' entry doesn't show up the hotkey mapping next to it ('C')
77114 AE - keep the Si3D/XSI-style for curves when performing topological operations
Compositing
76117 Some FXs are not working on Linux.
78187 Proxy Scaling : output wrong with transform & crop node
77961 dotXSI - Memory usage in FTK write and read is too high
Data Management
77629 RefModel: Referenced model are missing when reloading a scene using the same model many times.
59996 No pop up window to warn that disk is full when exporting external model
78136 Crash recovery on Linux... well... doesn't
78107 Customer scene that crashes on load even with QFE 14.
78041 Reference Models not saving with client scene even with QFE 14 (need Local Modification flags 'off')
78965 SPDL & Addon installation on the command line should have an option to FORCE reinstallation (when teh spdl already exists)
Documentation
79439 Online help update for SI3D Style slopes support
76296 Help info needed for Custom "DisplayInfo" Parameters
79874 Some links are not working on IRIX
General
78268 XSI-Corrupt Scenes(Crash)
76792 Invalid model connection crashes XSI on load
Modeling
75986 Crash with smooth weight (Apply smooth)
78886 Bulge / Twist -OP PROBLEM
79670 Trims: drawing of NURBS with trims: points at infinity
76000 Crash when adjusting the brush size (weight paint)
77865 Trims: Crash in trim tesselator on client data.
Rendering
77287 .scn association is binded to xsi.exe and not xsi.bat, so a lot of env vars are missing on startup
77289 .scn no longer work, it will simply start xsi without load the .scn
74503 Installer doesn't detect existing port for the service mi-ray3xsi2_0
77130 Loss of image clips: image clip are flagged "not used" even if shaders do use it
79275 Light list crashes on linux
77965 XSI cannot render 6k image... ran out of memory...
78369 MI_ADD_PLATFORM | Need to add motionblur.so/dll to the distribution
77827 LINUX / IRIX | XSIbatch can not render scenes that use the FX compositor
75984 Passes and overrides: (deactivation reduce to one *ONLY*) switching passes: speed and memory consumption (Client scene)
74879 Client scene: Load scene, switch pass = crash!
78196 Angle Discontinuity has no effect when the shape combiner operator is present.
78196 Angle discontinuity has no effect when shape combiner op is present
74879 Customer scene: Load scene, switch pass = crash!
Scripting/SDK
78077 Memory leak with scripted Operator (memory is growing up when doing a playback)
78833 SDK - Huge Memory Leak in Scripting Language (Phoenix)
78938 SDK - xsi -i : multiple spdl with same dll (Pheonix)
78937 SDK - xsi -u corrupting shader_plugin.mi (Pheonix)
77368 SDK - LINUX : Regression - Crash while parsing IsnerSpine.addon in current
Setup
78186 SPM | License reconnection dialog box no longer displays in the UI when license connection is lost
Simulation
75806 Transfer map crash on Nurbs.
77632 Hair: Horizontal Banding Artifacts with Shadows.
77358 HAIR - Save Scene on Frame other than where Hair and Obstacles were created causes hair to Disappear.
79331 HAIR - Crash with Render Region with customer scene if texture applied to root and tips of Hair
79801 Regression | Linux | Crash in 2.0.3 when loading customer scene [Libsparks.so]
