Ustanovka ne vihodit
Тема в разделе "Maya", создана пользователем -, 17 авг 2001.
Модераторы: Dark™, Skif
    Narod ustal ot poiskov po ustanovke StudioTools 9.6
    Kak ee postaviti???????
    U menia esti crack ?
    1) Install
    2) Go to X:\AW\COM\bin and launch lmtools.exe applet
    3) Go to the "System Settings" tab and get the
    "Disk Volume Serial Number" from there
    4) Open the supplied Aw.dat file and replace the
    HOSTID=DISK_SERIAL_NUM= (Put there that number you copied from above)
    5) Run lm.exe aw.dat
    6) Copy the aw.dat to C:\FlexLM
    7) Run the program
    nichevo ne vihodit,,,,,,,,,vedi sitema licencov v studio i maya odinakovi?????
    U menia stoit Win2000, bez seti,,,,ustanovil na Laptop Thinkpad
    Vot aw.dat kotorii shel vmeste s crackom. Disk Volume Serial Number: a87bc4be
    Gde chto eshe dobaviti,,, izmeniti?
    FEATURE Studio sgiawd 9.600 permanent uncounted F4A762AEBC136C3E \
    HOSTID=DISK_SERIAL_NUM=1234567
    FEATURE AutoStudio sgiawd 9.600 permanent uncounted C84A3A4975D6A85A \
    FEATURE SurfaceStudio sgiawd 9.600 permanent uncounted \
    3C4FD42CC55B8778 HOSTID=DISK_SERIAL_NUM=1234567
    FEATURE DesignStudio sgiawd 9.600 permanent uncounted \
    C39FE4DF7AF89A3F HOSTID=DISK_SERIAL_NUM=1234567
    FEATURE AliasRender sgiawd 9.600 permanent uncounted 99B9C5B05EB614A9 \
    FEATURE AliasPowerRender8 sgiawd 9.600 permanent uncounted \
    9403ED5A528CDC24 HOSTID=DISK_SERIAL_NUM=1234567
    FEATURE StudioAM sgiawd 9.600 permanent uncounted E5AF865A39B9E1D7 \
    FEATURE StudioAE sgiawd 9.600 permanent uncounted E5A7865A29C1E1D7 \
    FEATURE StudioADA sgiawd 9.600 permanent uncounted AC1DB3110E0C0C9D \
    FEATURE StudioDM sgiawd 9.600 permanent uncounted D205994FFB58E1D7 \
    FEATURE STNeutro sgiawd 9.600 permanent uncounted F21490560E20EDF9 \
    FEATURE STDBView sgiawd 9.600 permanent uncounted C2053C63EF64E837 \
    FEATURE STUGThicken sgiawd 9.600 permanent uncounted D426906C1E94E284 \
    FEATURE IDC sgiawd 9.600 permanent uncounted 9F615799C84B7532 \
    FEATURE CatDC sgiawd 9.600 permanent uncounted D95D016DDCEAB705 \
    Я думаю ты должен вставить в лицензии серийный номер вместо 1234567 тот, который выдаст lmtools при попытке получить hostid. Либо попробуй заменить 1234567 на 0000000, обычно без сети это проходит (по крайней мере на Майке).
    Успехов!
    @!#$! Прочитал внимательно у понял, что твой серийный номер - a87bc4be.
    Попробуй заменить 1234567 на него.
    Da menial ia 1234567 an a87bc4be nichevo ne vihodit.
    5) Run lm.exe aw.dat -----? chto eto znachit?
    Ето значит, надо запустить командную строку (окно DOS) и выполнить эту команду. У тебя должен быть обработан (крякнут) файл лицензии.
    kak zapustiti cherez Dos rascaji po konkretnei......ia novichok v koputerah?
    Попробую объяснить подробнее.
    1. Установи прогу и FlexLM
    2. Запусти FlexLM. Иди на закладку Diagnostics. Нажми Hostid's и запиши серийный номер.
    3. Вставь серийный номер в файл лицензии. (и сохрани ее :) )
    4. Скопируй лицензию в директорию, где лежит lm.exe.
    5. Выполни команду Start > Program > Accessores > Command Promt. У тебя откроется командная строка.
    6. Набери в командной строке lm.exe aw.dat
    7. Скопируй этот aw.dat C:\FlexLM
    8. Запускай прогу.
    9. Иди в магазин и оплачивай лицензию :)
    P.S. Это общие соображения, по опыту, как обычно все происходит. Могут быть отклонения в зависимости от программы.
    P.P.S. Если есть кряк или лицензия для Swiffworks for Maya 4.0 - буду очень рад. Дату менял, естественно, не помогает. Это было бы довольно глупая защита.
