Update к Vue d`Esprit до версии 4.1???
Воожу на сайте номер на который инсталирую программу они выдают вот это
Bad Serial Number!
The Serial Number that you have indicated is not correct. Don't panic! You probably just made a small mistake when entering it.
Please make sure that you type the exact number that is printed on the cover page of your product's User Guide.
This number is in the form of VUE4-xxxxx-#-xxxxx-xxx where 'x' depicts a digit and '#' a letter.
Press Back to correct the serial number and try again.
If for any reason you cannot get past this screen, please contact our technical support here.
Благополучно добыл Update 4.1 но там мой серийный номер поставлен в блок лист что с этим поделать???
