template Skeleton LE.mel
- Автор темы Modest
лови...
beginHelpText
templateSkeletonLE.mel
pthuriot
052404
-=OVERVIEW=-
Use this tool to help create and edit joint orientations for creatures.
Renamer tool for proper, and quick jointChain renaming.
Also CCT compatible (see Alias DVD: Custom Character Tools).
-=RETURN=-
-=NONE=-
-=EXAMPLES=-
Create any joint chain.
Run Template on the topNode of that chain (joint).
Edit up vectors for each joint and locations if needed. (The locator will show
the positive Z direction of rotation for the joint after the rebuild tool
is run).
Run Rebuild on the chain.
NOTE: Original chain must be a singular chain, with no multiple children branches.
SEE .PDF FILE/DVD FOR FULL DESCRIPTION AND USAGE EXAMPLES
To rename a chain, select the Top of the section you wish to rename.
Enter the correct prefix and select the suffix.
Hit the button.
-=REQUIRES=-
Maya 6.0 - end of renaming function uses retargeting tool calls.
-=UPDATES=-
version 1.0
052404 pthuriot initial, basic tool.
endHelpText
//beginProcHelp====================================================================
// PROCEDURE: templateSkeleton_reList (local)
// ARGUEMENTS: topnode of joint chain (string)
// RETURN: newly relisted joint chain array (string array)
// DESCRIPTION: will take the topNode and relist the joint children.
// simplified version--does no chain walking or error checking.
//endProcHelp======================================================================
proc string[] templateSkeleton_reList(string $topNode)
string $relisted[];
clear($relisted);
$relisted = `ls -type joint -sl -dag`;
// print "//=================================================\n";
// print "templateSkeleton_reList -->\n";
// print $relisted;
return $relisted;
// PROCEDURE: templateSkeleton_lockOff (local)
// ARGUEMENTS: node name (string)
// RETURN: NONE
// DESCRIPTION: will lock and make unkeyable all attrs on node.
proc templateSkeleton_lockOff(string $node)
string $attrs[] = `listAttr -k $node`;
for($each in $attrs)
setAttr -k 0 -l 1 ($node + "." + $each);
// PROCEDURE: templateSkeleton_createRotGrp (local)
// ARGUEMENTS: from joint (string),
// aimAt joint (string),
// parent node for rotGrp (string)
// RETURN: rotGroup name (string)
// DESCRIPTION: this will create the rotation group and return its name.
proc string templateSkeleton_createRotGrp(string $fromJt, string $toJt, string $xtraGrp, int $color)
string $rotGrpA = `group -em -name ($fromJt+"RotGrpAN_#")`;
string $rotGrpB = `group -em -name ($fromJt+"RotGrpBN_#")`;
string $rotGrpC = `group -em -name ($fromJt+"ManRotGrpCN_#")`;
string $loc[] = `spaceLocator -p 0 1 0 -n ($fromJt + "UpLoc_#")`;
select -r $loc[0];
color -ud $color;
if(!`attributeExists "toJoint" $loc[0]`)
addAttr -dt "string" -ln "toJoint" $loc[0];
if(!`attributeExists "toUpLoc" $fromJt`)
addAttr -dt "string" -ln "toUpLoc" $fromJt;
connectAttr -f ($fromJt+".toUpLoc")($loc[0]+".toJoint");
connectAttr -f ($fromJt+".rotGui") ($rotGrpB +".rx");
parent $loc[0] $rotGrpC;
parent $rotGrpC $rotGrpB;
parent $rotGrpB $rotGrpA;
pointConstraint $fromJt $rotGrpA;
aimConstraint -u 0 1 0 -wut "scene" $toJt $rotGrpA;
templateSkeleton_lockOff $rotGrpC;
setAttr -e -l 0 -k 1 ($rotGrpC +".rx");
templateSkeleton_lockOff $rotGrpB;
string $parent[] = `parent $rotGrpA $xtraGrp`;
return $parent[0];
// PROCEDURE: templateSkeleton_getAimUpObj (local)
// ARGUEMENTS: joint (string)
// RETURN: locator to be used as the up vector (string)
// DESCRIPTION: this will find the up vector locator via connections
proc string templateSkeleton_getAimUpObj(string $joint)
string $loc[] = `listConnections -s 0 -d 1 -scn 1 ($joint+".toUpLoc")`;
if(!`objExists $loc[0]`)
error("templateSkeleton_getAimUpObj -> "+$loc[0]+" doesn't exist");
return $loc[0];
// PROCEDURE: templateSkeleton_readSuffix (local)
// ARGUEMENTS: suffix ui (string)
// RETURN: actual suffix (string)
// DESCRIPTION: this will read the ui and return the correct string
proc string templateSkeleton_readSuffix(string $suffix_ui)
string $side;
int $rtLf = `radioButtonGrp -q -sl $suffix_ui`;
if ($rtLf == 3) {
$side = "Rt";
} else if ($rtLf == 2) {
$side = "Lf";
} else {
$side = "";
return $side;
// PROCEDURE: templateSkeleton (global)
// ARGUEMENTS: NONE
// RETURN: NONE
// DESCRIPTION: will create an extremely simple UI
global proc templateSkeletonLE()
int $winWidth = 325;
int $textWidth = ($winWidth/4);
if(`window -exists templateSkeleton_WinUI`)
deleteUI templateSkeleton_WinUI;
window -t "Template Skeleton LE v1.0" templateSkeleton_WinUI;
scrollLayout;
columnLayout -adj 1 -cal "center";
separator -height 10 -style "in";
gridLayout -numberOfColumns 3 -cellWidthHeight ($winWidth/3) 34;
string $joint_ui = `symbolButton -image "kinJoint.xpm"
-w ($winWidth/3) -h 32
-ann "Standard Joint Tool"
-c ("JointTool")`;
string $template_ui = `symbolButton -image "kinMirrorJoint_S.xpm"
-c "templateSkeleton_createTemp_doIt"
-ann "Create Template Skeleton"`;
string $reBuildChain_ui= `symbolButton -image "kinCreateDrawChain_S.xpm"
-c "templateSkeleton_reBuildChain_doIt"
-ann "Create Single Chain from Template Skeleton"`;
setParent ..;
separator -height 5 -style "in";
gridLayout -numberOfColumns 3 -cellWidthHeight ($winWidth/3) 15;
text -align "center" "Joint";
text -align "center" "Template";
text -align "center" "ReBuild";
setParent ..;
separator -height 5 -style "out";
rowColumnLayout -nc 2 -cw 1 $textWidth -cw 2 ($winWidth-$textWidth);
$chainNameDoIt_ui = `button -l "Rename"
-ann "Name the entire chain with the correct naming convention for selected"`;
$chainName_ui = `textField -w ($winWidth - 32)
-ann "Enter the name of the joints down the chain"`;
setParent ..;
$suffix_ui = `radioButtonGrp -cw 1 ($winWidth/4) -cw 2 ($winWidth/4) -cw 3 ($winWidth/4) -cw 4 ($winWidth/4) -cal 1 "left" -l "Suffix:" -numberOfRadioButtons 3 -labelArray3 "None" "Left" "Right" -sl 1`;
separator -height 10 -style "out";
setParent ..;
showWindow templateSkeleton_WinUI;
button -e -c ("templateSkeleton_chainRename "+$chainName_ui+" "+$suffix_ui) $chainNameDoIt_ui;
// PROCEDURE: templateSkeleton_createTemp_doIt (global)
// ARGUEMENTS: NONE
// RETURN: NONE
// DESCRIPTION: will create the Template Joint Chains via selection
global proc templateSkeleton_createTemp_doIt()
string $sel[] = `ls -sl -type "joint"`;
if(size($sel) < 1)
error("templateSkeleton_createTemp_doIt -> Select one or more Joints");
for($each in $sel)
templateSkeleton_createTemp $each;
select -cl;
// PROCEDURE: templateSkeleton_reBuildChain_doIt (global)
// ARGUEMENTS: NONE
// RETURN: NONE
// DESCRIPTION: will create the reBuilt Joint Chains from templates
// via selection
global proc templateSkeleton_reBuildChain_doIt()
string $sel[] = `ls -sl`;
if(size($sel) < 1)
error("templateSkeleton_reBuildChain_doIt -> Select at least one templateChain TopNode");
select -cl;
for($each in $sel)
templateSkeleton_reBuildChain $each;
select -cl;
// PROCEDURE: templateSkeleton_createTemp (global)
// ARGUEMENTS: joint chain top node (string)
// RETURN: new template joint chain group topNode (string)
// DESCRIPTION: this will create the template chain group
global proc string templateSkeleton_createTemp(string $chainTopNode)
//to surpress any cycle errors
cycleCheck -e off;
int $color = 1;
string $tempChainTop;
if(!`objExists $chainTopNode`)
error("templateSkeleton_createTemp -> "+$chainTopNode+" doesn't exist");
if(!`objectType -i "joint" $chainTopNode`)
error("templateSkeleton_createTemp -> "+$chainTopNode+" not of type \"joint\"");
string $grpTopNode = `group -em -n "templateSkeletonN_#"`;
string $jointTopNode = `group -em -n "jointsN_#"`;
string $xtrasTopNode = `group -em -n "xtrasN_#"`;
templateSkeleton_lockOff $grpTopNode;
templateSkeleton_lockOff $jointTopNode;
templateSkeleton_lockOff $xtrasTopNode;
if(!`attributeExists "rotGuiScale" $grpTopNode`) {
addAttr -ln "rotGuiScale" -at double -min 0 -dv 1.0 $grpTopNode;
setAttr -e -keyable true ($grpTopNode+".rotGuiScale");
string $fullPathNames[] = `parent $jointTopNode $xtrasTopNode $grpTopNode`;
// print $fullPathNames;
string $topJoint[] = `parent $chainTopNode $fullPathNames[0]`;
string $reListed[] = `templateSkeleton_reList $topJoint[0]`;
for ($i = 0; $i < (size($reListed) - 1); $i++)
if(!`attributeExists "rotGui" $reListed[$i]`) {
addAttr -ln "rotGui" -at double -min -360 -max 360 $reListed[$i];
setAttr -e -keyable true ($reListed[$i]+".rotGui");
string $rotGrp = `templateSkeleton_createRotGrp $reListed[$i] $reListed[($i+1)] $xtrasTopNode $color`;
connectAttr -f ($grpTopNode + ".rotGuiScale") ($rotGrp + ".sx");
connectAttr -f ($grpTopNode + ".rotGuiScale") ($rotGrp + ".sy");
connectAttr -f ($grpTopNode + ".rotGuiScale") ($rotGrp + ".sz");
templateSkeleton_lockOff $rotGrp;
$color++;
if($color == 9)
$color = 1;
select $grpTopNode;
print "Done creating Template Skeleton";
$tempChainTop = $grpTopNode;
return $tempChainTop;
// PROCEDURE: templateSkeleton_reBuildChain (global)
// ARGUEMENTS: template chain top node (string)
// RETURN: new rebuilt joint chain topNode (string)
// DESCRIPTION: this will create the rebuilt chain with correct axis
global proc string templateSkeleton_reBuildChain(string $chainTopNode)
string $rebuiltChain;
string $newSkele[];
clear($newSkele);
error("templateSkeleton_reBuildChain -> "+$chainTopNode+" doesn't exist");
string $joints[] = `ls -type joint -dag $chainTopNode`;
// print "templateSkeleton_reBuildChain --> $joints:\n";
// print $joints;
for($i = 0; $i < size($joints); $i++)
$newSkele[$i] = `joint -p $i 0 0`;
for($i = 0; $i < (size($joints)-1); $i++)
float $xyzs[] =`xform -q -a -ws -t $joints[$i]`;
xform -a -ws -t $xyzs[0] $xyzs[1] $xyzs[2] $newSkele[$i];
string $aimObj = `templateSkeleton_getAimUpObj $joints[$i]`;
string $aims[]=`aimConstraint -aim 1 0 0 -u 0 1 0 -wuo $aimObj -wut "objectrotation"
$joints[$i+1] $newSkele[$i]`;
float $rotss[]=`getAttr ($newSkele[$i]+".rotate")`;
delete $aims;
setAttr ($newSkele[$i]+".rotate") 0 0 0;
setAttr ($newSkele[$i]+".jointOrient") $rotss[0] $rotss[1] $rotss[2];
float $trans[] =`xform -q -a -ws -t $joints[$i]`;
xform -a -ws -t $trans[0] $trans[1] $trans[2] $newSkele[$i];
for($each in $newSkele)
setAttr ($each + ".rotateOrder") 3;
string $parentTest[] = `listRelatives -p -pa $newSkele[0]`;
if(`objExists $parentTest[0]`)
string $newParent[]=`parent -w $newSkele[0]`;
$rebuiltChain = $newParent[0];
else
$rebuiltChain = $newSkele[0];
delete $chainTopNode;
return $rebuiltChain;
print "Done reBuilding chain";
// PROCEDURE: templateSkeleton_chainRename (global)
// RETURN: NONE
// DESCRIPTION: will rename a chain via the UI settings.
// naming convention:
// prefix name + "J" for joint + alphabet + "Lf" or "Rt" (if applicable) + "_1"
global proc templateSkeleton_chainRename(string $chainName_ui, string $suffix_ui)
string $newlyNamed[];
clear($newlyNamed);
string $rename[];
clear($rename);
int $letter = 0;
string $namePrefix = `textField -q -tx $chainName_ui`;
string $readSuffix_ui = `templateSkeleton_readSuffix $suffix_ui`;
string $allCapLetters[] = {"A","B","C","D","E","F","G",
"H","I","J","K","L","M","N","O","P","Q","R",
"S","T","U","V","W","X","Y","Z"};
string $sel[] = `ls -type joint -sl`;
if(`size($sel)` < 1)
error("templateSkeleton_chainRename -> Select one joint");
string $selHier[] = `ls -type joint -dag $sel[0]`;
// print "templateSkeleton_chainRename --> $selHier:\n";
// print $selHier;
for ($i = 0; $i < size($selHier); $i++)
$rename[$i] = ($namePrefix + "J" + $allCapLetters[$letter] + $readSuffix_ui + "_1");
$letter++;
if($letter == 26)
$letter = 0;
// print "templateSkeleton_chainRename --> $rename:\n";
// print $rename;
$newlyNamed[(size($rename)-1)] = `rename $selHier[(size($rename)-1)] ($namePrefix + "JEnd" + $readSuffix_ui + "_1")`;
for($j = size($rename)-2; $j >= 0; $j--)
$newlyNamed[$j] = `rename $selHier[$j] $rename[$j]`;
//extra added function for maya 6 retargeting
for($each in $newlyNamed)
if($readSuffix_ui == "Lf")
setAttr ($each+".side") 1;
else if($readSuffix_ui == "Rt")
setAttr ($each+".side") 2;
else
setAttr ($each+".side") 0;
setAttr ($each + ".type") 18;
setAttr -type "string" ($each + ".otherType") $each;
print "Done renaming chain";
beginHelpText
pthuriot
052404
-=OVERVIEW=-
-=RETURN=-
-=NONE=-
-=EXAMPLES=-
is run).
Hit the button.
-=REQUIRES=-
-=UPDATES=-
version 1.0
endHelpText
string $relisted[];
clear($relisted);
// print $relisted;
return $relisted;
// RETURN: NONE
select -r $loc[0];
color -ud $color;
return $parent[0];
return $loc[0];
string $side;
if ($rtLf == 3) {
$side = "Rt";
$side = "Lf";
} else {
$side = "";
return $side;
// ARGUEMENTS: NONE
// RETURN: NONE
scrollLayout;
-c ("JointTool")`;
setParent ..;
setParent ..;
setParent ..;
setParent ..;
// ARGUEMENTS: NONE
// RETURN: NONE
if(size($sel) < 1)
for($each in $sel)
select -cl;
// ARGUEMENTS: NONE
// RETURN: NONE
// via selection
if(size($sel) < 1)
select -cl;
for($each in $sel)
select -cl;
cycleCheck -e off;
int $color = 1;
$color++;
if($color == 9)
$color = 1;
select $grpTopNode;
string $newSkele[];
clear($newSkele);
// print $joints;
delete $aims;
else
// RETURN: NONE
clear($newlyNamed);
string $rename[];
clear($rename);
int $letter = 0;
// print $selHier;
$letter++;
if($letter == 26)
$letter = 0;
// print $rename;
else
