Has anyone managed to crack syflex2.1 for Maya 5.0 ? I always get the following error: Wrong key Anyone ?
Я так понял ты не можешь крякнуть5 версию.Зайди в панель задач на виндусе.Найди панель диспетчер устройств.Затем сетевые контролеры.И сделай замыкание на себя т.е на саму систему виндус.Если что не понятно то потом напишу тебе по подробнее.Yiho wrote: > > Has anyone managed to crack syflex2.1 for Maya 5.0 ? > > I always get the following error: > > Wrong key > > > Anyone ?
Anime, But the problem is that wehenever I run the syflex server I get that wrong key error. All I did to create the key is: 1) Copied the key that the included program "getcode" generated 2) pasted it in "Syflex_21_keygen.exe" (from oddity2003) and generated the licence file. 3) Replaced syserv.exe with the new one provided Though whenever I run the syserv.exe, a log file is generated reporting me that wrong key error. Anime. Please help me. Do I use a wrong key generator ?Anime wrote: > > I think you need start Syflex Server... all simple...
Anime, No matter what I've tried, I always get "wrong key" error in syserv.log file syadm is just an interface to syserv. By just runnning syserv I get that error in the log file as well. Syadm provides the same error as well as it runs syserv in the background! I've used Oddity 2003's keygen and it just refuses to work here! All I do is: Copy the code that getCode.exe command provides to oddity's keygen to generate licence and copy that to the licence prompt within the setup for both server and plugin. I then replace the new provided licence server (syserv.ece) to the installed path. Reboot and try to run syserv (or syadm to get that running under and monitoring interface). Whenever I do that I only get "wrong key" error in the generated syserv.log file Please help! I need to get that plugin working ! If the archive that you've used to get that working under maya5.0 yourself is different from oddity's please tell me where can I get it from ? Please help
