sarwiya
Тема в разделе "Apple Shake", создана пользователем -, 10 июл 2002.
Модераторы: Григорий Чаленко
    hi I have the shake version 2.43.1118 n i have used the below key file to authorize but in my renderings i see shake demo copy text and dots all over please someone help. my computer doesnt have ethernet card or adapter so cannot get hostid but a friend of mine with hostid couldnt get it running anyway. helppppp
    FEATURE ShakeR nreal 2112.1118 permanent uncounted 1C978212C801 \
    HOSTID=ANY
    FEATURE ShakeI nreal 2112.1118 permanent uncounted 91EB4512C801 \
    HOSTID=ANY
    FEATURE ShakeX nreal 2112.1118 permanent uncounted 4EC77812C801 \
    HOSTID=ANY
    FEATURE ShakeV nreal 2112.1118 permanent uncounted 38777E12C801 \
    HOSTID=ANY
    FEATURE ShakeD nreal 2112.1118 permanent uncounted 70BB4C12C801 \
    HOSTID=ANY
    if there is anything else i need to download please do tell and if possible e-mail me : sarwiya@hotmail.com
    You must be a hacker a little bit...
    2.43 has a watermark protection. To remove it you need to open one of dll's in Shake root (i don't remember it's name, but you can find it by searching for the string "Nothing Real"), find string "Nothing Real" and REPLACE (do not REMOVE it) it by the empty characters.
    P.S. Do not forget, that all, that you will do with this dll is illegal. I write this to show Nothing Real (Apple) hole in protection of this software.
    well i tried it with a hex editor in nfx.dll and nrcc.dll but nothing happened. im not sure what i did was correct. how do i replace it with an empty character? i did it with space bar in a hex editor. do i eed to put null character there? if only i could have that modified dll. can u help me or mail me the damn dllto me at sarwiya@hotmail.com. do i need to add null character coz i m not able to do so in the hex editor ive got. thanx in anticipation wpiggy
    usually hostID with 000000000000 works
    the thing is everything works with the id given above but it renders with watermark and if i use ids like:
    FEATURE ShakeR nreal 2112.1118 permanent uncounted 78FE83132E9B \
    HOSTID=1234567890ab
    FEATURE ShakeI nreal 2112.1118 permanent uncounted BD5246132E9B \
    HOSTID=1234567890ab
    FEATURE ShakeX nreal 2112.1118 permanent uncounted 1A2E79132E9B \
    HOSTID=1234567890ab
    FEATURE ShakeV nreal 2112.1118 permanent uncounted 4CDE7F132E9B \
    HOSTID=1234567890ab
    FEATURE ShakeD nreal 2112.1118 permanent uncounted 18224D132E9B \
    HOSTID=1234567890ab
    replacing it with my hostid , it doesnt work at all. please help if someone could show me a solution or just post a working id ur using that would be a great help. i need it desperately.
    ive also tried replacing the string with null character in a hex editor that too doesnt work
    Write me on wpiggy@nwgsm.ru, or leave your mail there
    Actually I had the same problem with shake. You have to be sure - shake will render dots while you're using ANY in hostid. But you cannot just replace ANY with your ID 'cause codes generated for unique id's . For shake 2.4 I have key generator that makes this codes for me. The same problem when using computer without network card. HostID 0000000... cannnot be used. You have to set up at least network loopback adaptor to get normal host ID (i.e. ffff .... )
    Also I found that cracking flexlm floating licenses (as in Shake) is one of most hardest task :)) But you have to keep in mind - you use software that costs ~$9000 :)
    --ts
