Privetstvuyu!
Rebyat - PROBLEMA!
ne mogu otrenderit file batchom. vidayot:
// Result: Rendering... //
// Result: Percentage of rendering done: 0 (starting) //
// Result: Rendering Completed. See mayaRenderLog.txt for information. //
delayu diagnostiku:
Starting diagnostics...
Known Problems/Limitations
Warnings
- file2 has the advanced filter type turned on and is used as
a bump map. This is currently a limitation which will not render the
bump properly. It is best to set the filter type of the file texture
to MIPMAP.
- file4 has the advanced filter type turned on and is used as
to MIPMAP.
- there is shader glow in your scene, and autoExposure is turned on.
This may cause glow flicker over an animation. To remedy this,
render one frame in which the glow intensity looks desirable, then
apply the normalization factor (from the rendering output) as the
glow intensity to the shader glow node, and also turn off autoExposure.
For more information, please refer to the rendering reference manual.
Speed/Memory Implications
- moonShape1 has a high tessellation count: 214240.
It will be worthwhile to reduce the tessellation amount.
- nurbsSphere3|sun has a high tessellation count: 12960.
- sunShape has a high tessellation count: 441040.
- it can be useful to run your scene through "maya -optimizeRender"
before rendering. This can help optimize the scene for rendering.
Diagnostic Completed...
ne rederit ved v ruchnuyu.... (to yest soxranyat kajdi kadr....)
tretiy den muchayus....
4 raza s nula peredelival...
za sovet zaraneye spasibo!!!
Rebyat - PROBLEMA!
delayu diagnostiku:
Warnings
to MIPMAP.
to MIPMAP.
