Реальный мир Масштаб в 3ds MAX Помогите
(freakyCGI)
Hello ....
Всем привет....
ru:
Я всегда ищу, как сделать реальную мирового масштаба в 3ds MAX например взгляда на этот автомобиль, это выглядит настолько реальным, и так фактический размер, пожалуйста, я нужна помощь о том, как это сделать:
eng:
I always looking for how to do real world scale in 3ds MAX for example look at this car it looks so realistic and real dimensions so please I need help for how to do it exactly:
1:
2:
3:
4: The Field
Мои настройки системного блока:
My system unit settings:
* Я не уверен, что я должен поставить system unit setup и The display unit scale такой же ?????
I use 3ds MAX 2008 and 3ds MAX 2015.
My Email: freakyCGI@hotmail.com свяжитесь со мной, если вы хотите.
приветствует....;):)
LKI
U must use real world size models and Perspective match utilities(3ds max 2015 and if u use picture ) and it's will be ok. Real size model then background(if picture) perspective match and good, if back is not picture, if it made from 3d models so i have nothing to say...if all models real sized so its be good automatic
What about system unit settings: u do it well
(freakyCGI)
[QUOTE = "freakyyyy, post: 1154086, member: 165370"] k what about rest Xform? [/ QUOTE]
[QUOTE = "LKI, post: 1154053, member: 96636"] U must use real world size models and Perspective match utilities (3ds max 2015 and if u use picture) and it's will be ok. Real size model then background (if picture) perspective match and good, if back is not picture, if it made from 3d models so i have nothing to say ... if all models real sized so its be good automatic
What about system unit settings: u do it well [/ QUOTE]
Ok what about rest Xform?
telemix
"System Unit Scale" and "Display Unit Scale" may be different! You can change the "Display Unit Scale" as often as you want, it will not affect the scale of the scene. "Display Unit Scale" merely interprets the value of "System Unit Scale" for your convenience, the value that you need.
