Размещение объектов на не ровной поверхности
- Автор темы Nikkus
Есть огромное количество скриптов на данную тему. А в 2011 этот инструмент вообще встроенный (и функциональней всех встречаемых мною скриптов).
Вот мой любимый для 2009-го. Его используют в уроках 3D_Palace
Код:
macroScript paint_hair_floater
category:"paint"
toolTip:"paint"
offsetY = 20
globalZero = Point3 0 0 0
globalFirstHit = TRUE
globalDistNode = #(undefined,undefined,undefined)
globalDistNodeMirror = #(undefined,undefined,undefined)
globalHairCopy = #(undefined,undefined,undefined)
globalHairCopyMirror = #(undefined,undefined,undefined)
globalLastNode = #(undefined,undefined,undefined)
globalLastNodeMirror = #(undefined,undefined,undefined)
globalLastPos = #(undefined,undefined,undefined)
globalLastNormal = #(undefined,undefined,undefined)
globalLastPosMirror = #(undefined,undefined,undefined)
globalLastNormalMirror = #(undefined,undefined,undefined)
globalLastStr = 1
globalLastRadius = 1
globalUseDist = #(FALSE,FALSE,FALSE)
globalHairPos = #(globalZero,globalZero,globalZero )
globalHairNormal = #(globalZero,globalZero,globalZero)
globalHairPosMirror = #(globalZero,globalZero,globalZero )
globalHairNormalMirror = #(globalZero,globalZero,globalZero)
globalAlignNormal = 3
globalAlignStroke = 1
globalScaleOption = 1
globalScaleNormal = TRUE
globalScaleStroke = TRUE
globalScaleStrength = TRUE
globalScaleX = 1.0
globalScaleY = 1.0
globalScaleZ = 1.0
globalSourceNode = #()
globalInstance = FALSE
matrix3 fn GetMatrix hairPos mousePos normal str radius =
tm = matrix3 1
strNormal = 1
normalBase = 1
strengthBase = 1
strokeBase = 1
strStroke = 1
strStrength = 1
xvec = Point3 1 0 0
yvec = Point3 0 1 0
zvec = Point3 0 0 1
mouseVec = Point3 1 0 0
zvec = normalize normal
mouseVec = mousePos - hairPos
mouseVec = normalize mouseVec
xvec = cross mouseVec zvec
xvec = Normalize xvec
yvec = cross zvec xvec
yvec = normalize yvec
if (globalScaleOption == 1) then
else if (globalScaleOption == 2) then
str = globalScaleX
if (globalScaleY > str) then str = globalScaleY
if (globalScaleZ > str) then str = globalScaleZ
str = Length(mousePos - hairPos)/str
xvec = xvec * str
yvec = yvec * str
zvec = zvec * str
else if (globalScaleOption == 3) then
if (globalScaleNormal) then
strNormal = str*thePainterInterface.normalScale
if (globalAlignNormal == 1) then
normalBase = globalScaleX
else if (globalAlignNormal == 2) then
normalBase = globalScaleY
else if (globalAlignNormal == 3) then
normalBase = globalScaleZ
strNormal = strNormal/normalBase
zvec = zvec * strNormal
if (globalScaleStroke) then
strStroke = Length(mousePos - hairPos)
if (globalAlignStroke == 1) then
strokeBase = globalScaleX
else if (globalAlignStroke == 2) then
strokeBase = globalScaleY
else if (globalAlignStroke == 3) then
strokeBase = globalScaleZ
strStroke = strStroke/strokeBase
yvec = yvec * strStroke
if (globalScaleStrength) then
strStrength = radius
if (globalAlignStroke == 1)then
if (globalAlignNormal == 2)then
strengthBase = globalScaleZ
else if (globalAlignNormal == 3)then
strengthBase = globalScaleY
else if (globalAlignStroke == 2)then
if (globalAlignNormal == 1)then
strengthBase = globalScaleX
if (globalAlignStroke == 3)then
else if (globalAlignNormal == 2)then
strStrength = strStrength/strengthBase
xvec = xvec * strStrength
tm.row3 = xvec
tm.row1 = yvec
tm.row2 = zvec
else
tm.row1 = zvec
tm.row2 = yvec
tm.row3 = yvec
tm.row1 = xvec
tm.row2 = zvec
else
tm.row1 = zvec
tm.row2 = xvec
else
tm.row3 = zvec
tm.row1 = yvec
tm.row2 = xvec
else
tm.row1 = xvec
tm.row2 = yvec
tm.row4 = hairPos
return tm
fn StartStroke =
thePainterInterface.undoStart()
fn PlaceStroke =
localHit = Point3 0 0 0
localNormal = Point3 0 0 0
worldHit = Point3 0 0 0
worldNormal = Point3 0 0 0
str = 0.0f
radius = 0.0f
if (globalFirstHit == TRUE) then
globalFirstHit = FALSE
undo on
for i = 1 to 3 do
if (globalUseDist[i]) then
if (globalInstance) then globalHairCopy[i] = instance globalDistNode[i]
else globalHairCopy[i] = copy globalDistNode[i]
thePainterInterface.getHitPointData &localHit &localNormal &worldHit &worldNormal &radius &str 0
globalHairPos[i] = worldHit
globalHairNormal[i] = worldNormal
if (thePainterInterface.mirrorEnable == TRUE) then
if (globalInstance) then globalHairCopyMirror[i] = instance globalDistNode[i]
else globalHairCopyMirror[i] = copy globalDistNode[i]
thePainterInterface.getMirrorHitPointData &localHit &localNormal &worldHit &worldNormal 0
globalHairPosMirror[i] = worldHit
globalHairNormalMirror[i] = worldNormal
--retrieves the last hit point
--This gets whether the stroke point actually hit the mesh
--Since the user can paint off the mesh
--Right now we ignore this and create a cylinder regardless if they are painting on the mesh or not
hit = thePainterInterface.getIsHit -1
thePainterInterface.offMeshHitPos = globalHairPos[1]
for i = 1 to 3 do
globalScaleX = abs (globalDistNode[i].max[1] - globalDistNode[i].pos[1])
globalScaleY = abs (globalDistNode[i].max[2] - globalDistNode[i].pos[2])
globalScaleZ = abs (globalDistNode[i].max[3] - globalDistNode[i].pos[3])
minScaleX = abs (globalDistNode[i].min[1] - globalDistNode[i].pos[1])
minScaleY = abs (globalDistNode[i].min[2] - globalDistNode[i].pos[2])
minScaleZ = abs (globalDistNode[i].min[3] - globalDistNode[i].pos[3])
if (minScaleX > globalScaleX) then globalScaleX = minScaleX
if (minScaleY > globalScaleY) then globalScaleY = minScaleY
if (minScaleZ > globalScaleZ) then globalScaleZ = minScaleZ
tm = matrix3 1
globalHairCopy[i].transform = GetMatrix globalHairPos[i] worldHit globalHairNormal[i] str radius
--checks if the mirror is on, if so make sure to get that point and proces it also
-- Put mirror stuff here
globalHairCopyMirror[i].transform = GetMatrix globalHairPosMirror[i] worldHit globalHairNormalMirror[i] str radius
fn PaintStroke =
mirrorWorldHit = Point3 0 0 0
str = 0.0f
radius = 0.0f
for i = 1 to 3 do
for i = 1 to 3 do
tm = matrix3 1
projVec = Point3 0 0 1
if (thePainterInterface.getHitCount() > 1) then projVec = worldHit + (worldHit - globalLastPos[i])
else projVec = worldHit
globalHairCopy[i].transform = GetMatrix globalHairPos[i] projVec globalHairNormal[i] str radius
thePainterInterface.getMirrorHitPointData &localHit &localNormal &mirrorWorldHit &worldNormal 0
if (thePainterInterface.getHitCount() > 1) then projVec = mirrorWorldHit + (mirrorWorldHit - globalLastPosMirror[i])
else projVec = mirrorWorldHit
globalHairCopyMirror[i].transform = GetMatrix globalHairPosMirror[i] projVec globalHairNormalMirror[i] str radius
for i = 1 to 3 do
globalLastNode[i].transform = GetMatrix globalLastPos[i] worldHit globalLastNormal[i] globalLastStr globalLastRadius
globalLastNodeMirror[i].transform = GetMatrix globalLastPosMirror[i] mirrorWorldHit globalLastNormalMirror[i] globalLastStr globalLastRadius
for i = 1 to 3 do
globalLastNode[i] = globalHairCopy[i]
globalLastNodeMirror[i] = globalHairCopyMirror[i]
globalLastPos[i] = globalHairPos[i]
globalLastNormal[i] = globalHairNormal[i]
globalLastPosMirror[i] = globalHairPosMirror[i]
globalLastNormalMirror[i] = globalHairNormalMirror[i]
globalLastStr = str
globalLastRadius = radius
fn CancelStroke =
thePainterInterface.undoCancel()
fn EndStroke =
thePainterInterface.undoAccept()
fn systemEnd =
PaintHairRollout.PaintButton.checked = off
PaintHairRollout.PlaceButton.checked = off
rollout PaintHairRollout "Paremeters" width:211 height:300
Button SourceButton "Set Sel. As Source" pos:[86,10] width:101 height:24
label SourceObject "Source Object" pos:[11,16] width:72 height:15
pickButton Dist1Button "Pick Distribution 1" pos:[86,41] width:101 height:24
pickButton Dist2Button "Pick Distribution 2" pos:[86,70] width:101 height:24
pickButton Dist3Button "Pick Distribution 3" pos:[86,101] width:101 height:24
checkbox UseDist1 "Use As Dist" pos:[7,45] width:76 height:15
checkbox UseDist2 "Use As Dist" pos:[7,74] width:76 height:15
checkbox UseDist3 "Use As Dist" pos:[7,104] width:76 height:15
checkButton PlaceButton "Place" pos:[7,135] width:104 height:24
checkButton PaintButton "Paint" pos:[7,163] width:104 height:24
button Options "..." pos:[113,135] width:41 height:24
checkbox UseInstance "Instance Copies" pos:[7,193] width:120 height:15
label Align "Align Objects " pos:[2,198+offsetY] width:66 height:15
label Align2 " Axis To Normal " pos:[108,198+offsetY] width:92 height:15
dropDownList AlignNormal "" pos:[72,198+offsetY] width:37 height:21 items:#("X", "Y", "Z") selection:3
label Align3 "Align Objects " pos:[2,222+offsetY] width:66 height:15
label Align4 " Axis To Stroke " pos:[108,222+offsetY] width:92 height:15
dropDownList AlignStroke "" pos:[72,222+offsetY] width:37 height:21 items:#("X", "Y", "Z") selection:1
label Align5 "Scale Options " pos:[2,246+offsetY] width:66 height:15
dropDownList ScaleOptions "" pos:[72,246+offsetY] width:100 height:21 items:#("None", "Uniform Scale", "Custom Scale") selection:1
checkbox chkScaleNormal "Scale Based On Normal" pos:[28,272+offsetY] width:145 height:22 checked:true
checkbox chkScaleStroke "Scale Based On Stroke" pos:[28,292+offsetY] width:145 height:22 checked:true
checkbox chkScaleStrength "Scale Based On Strength" pos:[28,312+offsetY] width:145 height:22 checked:true
on SourceButton pressed do
globalSourceNode = $
on Dist1Button picked obj do
globalDistNode[1] = obj
Dist1Button.text = obj.name
UseDist1.checked = TRUE
globalUseDist[1] = TRUE
on Dist2Button picked obj do
globalDistNode[2] = obj
Dist2Button.text = obj.name
UseDist2.checked = TRUE
globalUseDist[2] = TRUE
on Dist3Button picked obj do
globalDistNode[3] = obj
Dist3Button.text = obj.name
UseDist3.checked = TRUE
globalUseDist[3] = TRUE
on UseDist1 changed state do
globalUseDist[1] = state
on UseDist2 changed state do
globalUseDist[2] = state
on UseDist3 changed state do
globalUseDist[3] = state
on UseInstance changed state do
globalInstance = state
on PlaceButton changed state do
if (PaintButton.checked) then
PaintButton.checked = FALSE
thePainterInterface.EndPaintSession()
if thePainterInterface.InPaintMode() then
PlaceButton.checked = FALSE
else
PlaceButton.checked = TRUE
thePainterInterface.initializeNodes 0 globalSourceNode
thePainterInterface.pointGatherEnable = FALSE
thePainterInterface.buildNormals = TRUE
thePainterInterface.offMeshHitType = 2
thePainterInterface.drawTrace = FALSE
thePainterInterface.ScriptFunctions startStroke placeStroke endStroke cancelStroke systemEnd
thePainterInterface.startPaintSession()
on PaintButton changed state do
if (PlaceButton.checked) then
else
PaintButton.checked = TRUE
thePainterInterface.ScriptFunctions startStroke paintStroke endStroke cancelStroke systemEnd
On Options pressed do
thePainterInterface.paintOptions()
on AlignNormal selected sel do
globalAlignNormal = sel
on AlignStroke selected sel do
globalAlignStroke = sel
on ScaleOptions selected sel do
globalScaleOption = sel
on chkScaleNormal changed state do
globalScaleNormal = state
on chkScaleStrength changed state do
globalScaleStrength = state
on chkScaleStroke changed state do
globalScaleStroke = state
on PaintHairRollout oktoclose do
thePainterInterface.endPaintSession()
-- create the rollout window and add the rollout
if FloaterExampleFloater != undefined do
closerolloutfloater FloaterExampleFloater
Floater = newRolloutFloater "Paint Hair Floater" 220 425
addRollout PaintHairRollout Floater
Выделяешь и копируешь весь код, вставляешь в блокнот и сохраняешь. Потом меняешь у файла формат с txt на ms (переименовываешь). После чего бросаешь его в окно макса. В настойке ищешь категорию "paint", после чего, либо выносишь на панель, либо назначаешь горячую клавишу.
И еще один вариант, как можно впихнуть скрипт в макс http://www.render.ru/forum/viewtopic.php?post_id=886002#886002 (сообщение 13)
