Проблема с лицензией на РАТ 5.5.1
Fixxxer 4851
здесь уже обсуждалось то как рушиться pixard на AMD машинах
у меня похожая проблема только машина интел П4 1,5 ГГЦ
следуею строго по вот этому порядку
1. Install RAT and all additional Options
2. Do not Reboot.
3. Run the Patcher.exe and choose your root Pixar dir
where you installed.
4. Over write the pixard.exe with our one include here.
5. Edit the license.dat. Check your_server to your actual
server name. Do not change anything else.
6. Reboot and Enjoy!
If you dont know how to Install RAT, follow
those little instructions :
1. run "pixar_rat.msi"
2. choose "Artist Workstation" as installation profile
3. for Server Location, enter the name of your machine and check the
box that says "Install License Server locally"
4. choose "Alfred Server" for Remote Execution Server and check the box
that says "Install Maitre-d Locally"
5. select additional components
6. choose "Rendering Workstation" as Prman installation profile
7. skip the license file editor
при запуске сервера получается вот что в логе
17:55:22 (lmgrd) Done rereading
17:55:22 (lmgrd) FLEXlm (v8.2a) started on fixxxer (IBM PC) (9/16/2003)
17:55:22 (lmgrd) FLEXlm Copyright 1988-2002, Globetrotter Software, Inc.
17:55:22 (lmgrd) US Patents 5,390,297 and 5,671,412.
17:55:22 (lmgrd) World Wide Web: http://www.globetrotter.com
17:55:22 (lmgrd) License file(s): C:\Program Files\Pixar\license-2.0\license.dat
17:55:22 (lmgrd) lmgrd tcp-port 7498
17:55:22 (lmgrd) Starting vendor daemons ...
17:55:22 (lmgrd) Started pixard (pid 3564)
17:55:22 (pixard) Server started on fixxxer for: RATutils
17:55:22 (pixard) PhotoRealistic-RenderMan PRMan-INTEL PRMan-INTEL-NT
17:55:22 (pixard) PRMan-SGI RATalfred RATmtor
17:55:22 (pixard) RATslim RATalfserver RAT-NT
17:55:22 (pixard) RAT-Linux RAT-Irix
17:55:22 (pixard) Vendor daemon can't talk to lmgrd ()
17:55:37 (lmgrd) Vendor daemon died with status 28
17:55:37 (lmgrd) Since this is an unknown status, lmgrd will
17:55:37 (lmgrd) attempt to re-start the vendor daemon.
17:55:37 (lmgrd) REStarted pixard (pid 3656)
17:55:37 (pixard) Server started on fixxxer for: RATutils
17:55:37 (pixard) PhotoRealistic-RenderMan PRMan-INTEL PRMan-INTEL-NT
17:55:37 (pixard) PRMan-SGI RATalfred RATmtor
17:55:37 (pixard) RATslim RATalfserver RAT-NT
17:55:37 (pixard) RAT-Linux RAT-Irix
17:55:37 (pixard) Vendor daemon can't talk to lmgrd ()
17:55:52 (lmgrd) Vendor daemon died with status 28
17:55:52 (lmgrd) Since this is an unknown status, lmgrd will
17:55:52 (lmgrd) attempt to re-start the vendor daemon.
17:55:52 (lmgrd) REStarted pixard (pid 3812)
и так далее по кругу
этот пиксард почемуто не может говорить с лмгрд и постоянно рестартуется
в результате сервер не запущен и МТОР не рестартуецца...
у когонить было чегото подобное ???
вот моя лицензия
SERVER fixxxer 0069BABEF00D 7498
USE_SERVER
DAEMON pixard "C:\Program Files\Pixar\license-2.0\pixard.exe"
FEATURE RATutils pixard 5.500 permanent 500 0CFC282A5DBD6D6870B1 \
VENDOR_STRING=Midnight \
vendor_info=SIG={FWKAYeGNIR_hKElHTAXUATIt[SVMGVGTZS@m]_Z@OY^JNPCHT]QP[HCC\THPDUnV\rVYiJQp[A\]]LZNn_IRMTK[EnFE|XYd} \
ck=31
FEATURE PhotoRealistic-RenderMan pixard 11.000 permanent 100 \
EC2CD81AAA5C3A46285B VENDOR_STRING=Midnight \
vendor_info=SIG={X]I]XZBHWW@JXLQJZhJXYUGRWYYMO`AByTJO_FXNC@RDm_W[KSuLTGUYiPDJIEy_UjYHY^[NXLMPHFBWAVHPTSZKSuFTRQXs} \
ck=78
FEATURE PRMan-INTEL pixard 11.000 permanent 100 1CDCA84C300B78D8D03F \
VENDOR_STRING=Midnight ck=62
FEATURE PRMan-INTEL-NT pixard 11.000 permanent 100 \
AC7CD83C3E42B2BE2E40 VENDOR_STRING=Midnight ck=48
FEATURE PRMan-SGI pixard 11.000 permanent 100 AC7CB8BC7EE50494531B \
VENDOR_STRING=Midnight ck=99
FEATURE RATalfred pixard 5.500 permanent 100 2CDC189C6A28835723AC \
VENDOR_STRING=Midnight ck=55
FEATURE RATmtor pixard 5.500 permanent 100 ACDCB84C0B15101F13CA \
VENDOR_STRING=Midnight ck=36
FEATURE RATslim pixard 5.500 permanent 100 3CAC284C6EFEF969B761 \
VENDOR_STRING=Midnight ck=105
FEATURE RATalfserver pixard 5.500 permanent 100 7CDC789C3F547FBEC5CC \
VENDOR_STRING=Midnight ck=59
FEATURE RAT-NT pixard 5.500 permanent uncounted AC0C880CF1A83A19609F \
VENDOR_STRING=Midnight HOSTID=ANY ck=68
FEATURE RAT-Linux pixard 5.500 permanent uncounted \
3CECA8DC75429328E64F VENDOR_STRING=Midnight HOSTID=ANY ck=88
FEATURE RAT-Irix pixard 5.500 permanent uncounted \
CC4C78ACEABEF741F05B VENDOR_STRING=Midnight HOSTID=ANY ck=146
Fixxxer 4851
вот нашел какуюто информацию по этим ошибкам
есть ли у кого какиенить мысли по этому поводу ?
Q8.5 Vendor daemon can't talk to lmgrd
This means a pre-v3.0 lmgrd is being used with a v3.0+ vendor daemon.
Simply use the latest version of lmgrd (MUST be a version equal to or greater than the vendor daemon version).
>>> этого быть не может потому что пиксард версии 7,2g лмгрд 8,2а
(Rare): This can also happen if TCP networking doesn't function on the node where you're trying to run lmgrd.
Q8.6 Vendor daemon died with status n...Since this is an unknown status, lmgrd will attempt to re-start the vendor daemon.
Often this is accompanied by printing a port number which increases over and over.
lmgrd tries to start the vendor daemon using the DAEMON line in the license file, which looks like:
DAEMON demo /usr/bin/demo
The /usr/bin/demo is a path to a binary, and there's something wrong with either the path or the binary itself.
One way to debug this is to run vendor daemon directly, using this path, and problem then becomes more apparent.
Fixxxer 4851
антивирус доктор вэб
вырубил его через таск манагер и попробовал перестартовать лицензионный сервер
ничего не изменилось
пробовал поставить дома
все прошло идеально
на работе не хочет
такое впечатление что тут чтото с сетью и она как то хитро сделана так что
пиксард не может общаться с лмгрдой а также крашется альфкмд
