Poser4->C4D r8 OK!
Тема в разделе "Cinema 4D", создана пользователем Dyusha, 19 апр 2003.
  1. Dyusha
    Dyusha Активный участник
    В общем тема такая. Получилось в 8 синьке загрузить позеровский файл через старый плугин. Возникает только некоторые неудобства. Переодически надо тыкать носом какой позеровский файл грузить. И с текстурой проблем (ну не совсем). Некоректно отображается бамп. Приходиться рихтовать.
    Ставится плуг через старый унблаклистер.
    Poser Plugin for CINEMA 4D R8
    Requires valid installation of CINEMA 4D Release 8!
    Instructions for patching Poser Plugin for CINEMA 4D R8:
    1.Install Poser 4 or 4.03
    2.Install Poser Pro Pack.
    3.Install Poser Pro Pack SR3
    Select NO when prompted to search for your Poser installation, then manually browse to your Poser folder.
    This version contains only the core Poser Pro Pack Service Release 3 application. At the end of the installation you will be prompted to install plugins, please select "no". If you wish to install the plugins, please run the plugin installers separately.
    4.Rename CINEMA_4D.exe CINEMA_4D_XL.exe
    5.Install Poser Plugin for CINEMA 4D XL
    6.Rename CINEMA_4D_XL.exe CINEMA_4D.exe
    7.Rename CINEMA_4D_XL.rsr CINEMA_4D.rsr
    8.Run the patcher and click the "Cr*ck It" button and browse to the file from the following that you wish to remove the Blacklisting from:
    Poser Pro Pack = Poser.exe (In your Poser 4 Directory)
    Poser Plugin for CINEMA 4D XL = PzrForC4D.cdl (In your CINEMA_4D_R8\Plugins\PzrForC4D Directory)
    8.Get this FREE plugin to fix Poser 4 Pro Pack Cinema 4D plugin mess: Poser Plugin Bug Fix
    9.When you first run Poser Pro you will be asked to enter your name and serial numbers for both Poser & the Pro Pack.
    To select a Poser file to open and host within CINEMA 4D:
    1.Select the Plug-Ins tab in your Menu bar then click the Poser Object entry.
    2.When starting the plug-in for the first time, the Poser Location window will appear. Click the File button and browse to locate the file Poser.dta in the Poser directory. Click OK to continue.
    3.Browse to locate the Poser scene (*.PZ3 or *.PZZ) you wish to host. Open the scene by double-clicking it or by selecting it and clicking the Open button.
    Очень интересный ресурс для интересующихся экспортом OBJ Poser файлов с правильным наложением текстур.
    Бесплатные плугины:
    http://www.amazonescity.com/download/free3dformembers/index.php
    http://www.amazonescity.com/download/free3dformembers/oldplug.html
  2. Dyusha
    Плугины и инструкцию отправил FSV
    Ну спасибо, ну молодца!
    добавлю только, что если у кого эта фигня осталась от синемы7, то достаточно заменить название CINEMA_4D_XL.rsr на CINEMA_4D.rsr.
    Лежит в плагинах :))
  5. Poser-Models
    Poser-Models Активный участник
    Господа кодда все это проделываешь C4D спрашивает локацию файла Poser.dta (он обнаруживается в директории с Poser 4) А что сли указать такой же файл из директории с Poser 5
  6. Dyusha
    Пробовал. Но потом при загрузке позеровского файла плуг ругается, говорит неправильный серийный номер позера.
    PS Укурьезников на сайте не зря написано что плуг только для Позера Про Пак и Синьки 7 и выше. Для 5 не канает.
