Помогите установить плаг Stich!
Тема в разделе "Общие вопросы", создана пользователем Blackmoon 593, 29 ноя 2001.
  1. Blackmoon 593
    Blackmoon 593 Знаток
    Версия 1.05 для 4МАХ.
    Вот инфо на английском, надёюсь поймешь :)
    Installation Instructions:
    Start with a clean computer reboot, especially if u were
    just running max.
    1) Open your 3dsmax4 plugin.ini file and put in the entries
    below (note the categories in brackets):
    Stitch Plug-in=C:\3dsmax42\plugins\Digimation
    Stitch Help=C:\3dsmax42\Help\Stitch Manual.chm
    NOTE: Obviously, change the 3dsmax4 directory to match your
    installation directory.
    2) Move the files from their respective directories to your
    3dsmax4 directories (ie. \3dsmax4\Scenes\ is moved to
    <installed max4 dir>\Scenes).
    NOTE: Any files not in a sub-directory of the 3dsmax4 directory
    go in the root directory of 3dsmax4, such as DigiSrv4.exe.
    3) Once installed run the DigiP_register.bat file that should
    now be in your 3dsmax4 installation directory. Start max4
    and create a server name by hitting add (use your computers
    network id). Register using the keygen that has been included
    with this release.
    NOTE: If you already have digisrv4.exe installed and registered,
    there is no need to do it again.
    Thats all. Have fun and dont forget to buy it if you like it.
