Ошибки в MAXScript при запуске 3DSMax
Тема в разделе "MAXScript", создана пользователем skivan, 26 дек 2006.
Модераторы: Savin Denis
  1. skivan
    skivan Пользователь сайта
    После инсталяции при запуске 3DSMax выскакивают ошибки:(на картинке) а в логах MAxScript вот это :
    Welcome to MAXScript.
    -- Error occurred during fileIn in <File:C:\Program Files\Autodesk\3ds Max 9\stdplugs\stdscripts\CharacterPluginObject.ms>
    >> MAXScript Auto-load Script Error - C:\Program Files\Autodesk\3ds Max 9\stdplugs\stdscripts\CharacterPluginObject.ms Exception: -- Syntax error: at dotNetControl, expected <rollout control>
    -- In line: function g <<
    -- Error occurred during fileIn in <File:C:\Program Files\Autodesk\3ds Max 9\stdplugs\stdscripts\MergeAnimation.ms>
    >> MAXScript Auto-load Script Error - C:\Program Files\Autodesk\3ds Max 9\stdplugs\stdscripts\MergeAnimation.ms Exception: -- Syntax error: at dotNetControl, expected <rollout control>
    -- In line: dotNetControl l <<
    -- Error occurred during fileIn in <File:C:\Program Files\Autodesk\3ds Max 9\stdplugs\stdscripts\NET_ListViewWrapper.ms>
    >> MAXScript Auto-load Script Error - C:\Program Files\Autodesk\3ds Max 9\stdplugs\stdscripts\NET_ListViewWrapper.ms Exception: -- Compile error: Undeclared variable: dotNetClass
    -- In line: m_dnColor = dotNetClass " <<
    -- Error occurred during fileIn in <File:C:\Program Files\Autodesk\3ds Max 9\stdplugs\stdscripts\NET_TreeViewWrapper.ms>
    >> MAXScript Auto-load Script Error - C:\Program Files\Autodesk\3ds Max 9\stdplugs\stdscripts\NET_TreeViewWrapper.ms Exception: -- Compile error: Undeclared variable: dotNetClass
    >> MAXScript MacroScript Compile - C:\Program Files\Autodesk\3ds Max 9\UI\MacroScripts\Macro_Help.mcr Exception: -- Syntax error: at dotNetControl, expected <rollout control>
    -- In line: button b <<
    >> MAXScript MacroScript Compile - C:\Program Files\Autodesk\3ds Max 9\UI\MacroScripts\Macro_NamedSelSets.mcr Exception: -- Syntax error: at dotNetControl, expected <rollout control>
    -- In line: dotNetControl v <<
    >> MAXScript MacroScript Compile - C:\Program Files\Autodesk\3ds Max 9\UI\MacroScripts\Macro_BakeTextures.mcr Exception: -- Syntax error: at dotNetControl, expected <rollout control>
    -- In line: group " <<
    Кто нибудь сталкивался с это ошибкой ? И что мне теперь делать :)
      91,4 КБ
      454
  2. skivan
    Вопрос закрыт.
    Странно но у меня небыл установлен 2-ой Framework.
