Ошибка при запуске и использовании нод материалов в maya
кирилл величко
Здравствуйте, подскажите пожалуйста, что это?
Initialized VP2.0 renderer {
Version : 2016.11.35.12. Feature Level 5.
Adapter : GeForce GTX 1050 Ti/PCIe/SSE2
Vendor ID: 4318. Device ID : 7298
Driver : .
API : OpenGL V.4.6.
Max texture size : 16384 * 16384.
Max tex coords : 32
Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
Shader compiler profile : (Best card profile)
Active stereo support available : 0
GPU Memory Limit : 4096 MB.
CPU Memory Limit: 15520 MB.
OpenCL evaluator is attempting to initialize OpenCL.
Detected 1 OpenCL Platforms:
0: NVIDIA Corporation. NVIDIA CUDA. OpenCL 1.2 CUDA 9.1.84.
Supported extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts cl_nv_create_buffer
OpenCL evaluator choosing OpenCL platform NVIDIA Corporation.
Choosing OpenCL Device GeForce GTX 1050 Ti. Device Type: GPU Device is available.
Unable to execute xgen.mel.00:00:00 752MB WARNING | node "MayaMultiplyDivide" is already installed
00:00:00 752MB WARNING | node "MayaClamp" is already installed
00:00:00 752MB WARNING | node "MayaGammaCorrect" is already installed
00:00:00 752MB WARNING | node "MayaCondition" is already installed
00:00:00 752MB WARNING | node "MayaReverse" is already installed
00:00:00 930MB | log started Sun Feb 4 13:01:29 2018
00:00:00 930MB | Arnold 5.0.1.0 [8ea063c7] windows icc-17.0.2 oiio-1.7.15 osl-1.9.0 vdb-4.0.0 clm-1.0.3.513 rlm-12.2.2 2017/06/27 18:48:44
00:00:00 930MB | host application: MtoA 2.0.1 2ad5768c (master) Maya 2018
00:00:00 930MB | running on RED21, pid=12280
00:00:00 930MB | 1 x AMD Ryzen 5 1500X Quad-Core Processor (4 cores, 8 logical) with 16336MB
00:00:00 930MB | Windows 8 Professional (version 6.2, build 9200)
00:00:00 930MB | soft limit for open files raised from 2048 to 2048
00:00:00 930MB |
00:00:00 930MB | loading plugins from C:/solidangle/mtoadeploy/2018/shaders ...
00:00:00 930MB | loading plugins from C:/solidangle/mtoadeploy/2018/procedurals ...
00:00:00 930MB | loaded 124 plugins from 12 lib(s) in 0:00.01
00:00:00 930MB | loading plugin: C:/solidangle/mtoadeploy/2018/shaders/mtoa_shaders.dll ...
00:00:00 930MB WARNING | node "MayaMultiplyDivide" is already installed
00:00:00 930MB WARNING | node "MayaClamp" is already installed
00:00:00 930MB WARNING | node "MayaGammaCorrect" is already installed
00:00:00 930MB WARNING | node "MayaCondition" is already installed
00:00:00 930MB WARNING | node "MayaReverse" is already installed
00:00:00 930MB WARNING | node "MayaBlendColors" is already installed
00:00:00 930MB WARNING | node "MayaSamplerInfo1D" is already installed
00:00:00 930MB WARNING | node "MayaSamplerInfo2D" is already installed
00:00:00 930MB WARNING | node "MayaPlusMinusAverage1D" is already installed
00:00:00 930MB WARNING | node "MayaPlusMinusAverage2D" is already installed
00:00:00 930MB WARNING | node "MayaPlusMinusAverage3D" is already installed
00:00:00 930MB WARNING | node "MayaRemapValueToValue" is already installed
Там еще много, но в этом сообщении все не помещается
