Опять обновили!!! ))) встречайте!!! на это раз rh30sr_en_20050615
M174
...как обычно - никаких новостей на офф.сайте, собственно всё в названии темы... наверно SR4a какой-нибудь :)... закинул во флешгет - 17% уже :) ... кстати что странно - размер слегка уменьшился по сравнению с 20050606 щас весит 44.457Кб (ну прям как ретайл версия третьей рины:))... как сказал mono;) - крайне рекомендуется к установке! всем качать!
M174
сорри за пустую тему - я не специально, просьба к модераторам удалить пустую! заранее спасибо! :)
http://download.mcneel.com/whatsnew.asp?rel=51
Читать !!!
Download Rhino 3.0 Service Release 4 Release Candidate 2 now.
What's New, SR4 RC2 (15-Jun-2005)
Bug Fixes:
Download Page now works correctly with Mozilla FireFox.
Import STEP: fixed a bug that caused Rhino to fail to read files with incorrectly formatted schema names.
Installer: Fixed several bugs related to patching existing installations of Bonus Tools and other plug-ins.
What's New, SR4 RC1 (20-May-2005)
New Features:
Bonus Tools are now included in Service Release 4.
Dimension display: A new document property controls whether dimension text is displayed horizontal in each viewport.
Help command: The help file in all languages now remembers the size and location and reopens in that position.
Open 3DM: File Locking - when a file is in use by one user, it can only be opened in read-only mode by another user.
Enhanced Features:
EditScript command: New dialog box layout.
Bug Fixes:
Align command: Problem with edge alignment fixed.
BoundaryExtrude command: Preselection of surfaces is now permitted.
BoundingBox command: The BoundingBox command failed on some curves. This is fixed.
CreateUVCrvOnSrf command: Instead of cancelling the selection when you pre-select one surface and at least one curve, the command will try to create the uv curves. If anything else is pre-selected, then all is unselected and post-selection begins.
Delete: Invisible bad objects in the file could be selectable by SelAll or SelBadObjects but it did not respond to Delete. This is fixed.
EditScript command: Dialog box now remembers previous size and location.
EditScript command: A new "Close" item on the File menu closes the window but saves the current text during the Rhino session.
ExtractControlPolygon command: Failed on surfaces with singularities. This is fixed.
FilletPolyline command: If segments are too small to be filleted, a message displays.
Fin and OffsetNormal commands: Now allow pre-picking curves.
Fin command: Now works with a curve preselected and only prompts for the surface.
Layout command: Running the Layout command in Windows ME caused a crash. This is fixed.
License Manager: License conflicts occurred during time-consuming tasks such as loading a large file. This is fixed.
MoveEdge command: The prompts have been tuned up.
MoveEdge command: The VectorDirection and PlaneDirection prompts have been removed.
Pipe command: Making a thick pipe with both start radii the same crashed Rhino. This is fixed.
Plane: The Plane command will no longer accept zero length or width input.
PopUpMenu command: The PopUpMenu command opened the menu, but failed to execute the command. This is fixed.
Save DWG/DXF: Objects exported via dwg had color incorrectly set by object, even if they had color by layer in Rhino. This is fixed.
Scale1D command: Made a bad object when scaling a cylinder along its axis. This is fixed.
SplitFace command: Using the Near object snap to split the face caused the wrong face to be split. This is fixed.
STEP: Several import bugs have been fixed.
Undo command: Commands that delete large numbers of objects now undo more quickly.
VRBSrf command: Crashed when making blend with 0 radius at both ends. This is fixed.
Worksession command: Attaching non-Rhino files such as DWG, LWO, OBJ, to Worksession incorrectly caused the attached file to become active. This is fixed.
Zoo: Several problems with the Zoo license manager have been fixed.
Бла бла бля))
есть места и поинтересней чем в лоб через оф. сайт )) напрягаем мозги ..И!
to mono25
Читать !!!
!!! Rhino 3.0 Service Release 4 Release Candidate 2 !!!
Суть в том, что особо нервных просьба не беспокоится-
SP4- по лишь кандидат на релиз !!!
Баги ловят, качать по 45 мег каждый раз смысла нет.
Ждем окончательный...
Rhino 3.0 Service Release 4 Release Candidate 2 - What's New
читать тут - инфа об этой заморочке
>>>>h..p://download.mcneel.com/whatsnew.asp?rel=51
для танкистов - брать тут
=>>>ftp://ftp2.mcneel.com/pub/rhino/3.0/sr/=
45,814,017 rh30sr_en_20050606.exe
45,524,692 rh30sr_en_20050615.exe
AZ'ART шож ты делаешь)) блин кому нада те и так знают ((
за каким писать где и что берешь... макнил дыру забыл закрыть на честность надеються ) а ламо как кинеться) и хана буит малине....
а на тему багофф 1 глюк неставиться на просто рино без сервис пака3)) и бонустулза)))
на тему нерных их нет просто я паранойк и шиз и спавка есть.......
Эта "дыра" существует как мне помнится с Рины версии 1 :cool:
и в форуме не раз освещалась.
Секретов никаких я не открыл, а ламо становятся со временем гуру...
8)
mono 25 ты чего козлишся? Rhinu пользуют не так уж и много народу, да и дыра уже 100 лет открыта.
aaj
Господа у меня доступ к ftp закрыт, где еще можно скачать?
