Для тех, у кого нет VIZ4 или по каким-либо причинам не хочет его ставить - берём инсталлятор Autodesk VIZ 4 to 3ds max 5 Compatibility Utility: хттп://vipdesign.fatal.ru/util/viz42-to-max5.exe
После установки получаем следующие недостающие примочки VIZa:
. Wall, Door, and Window objects
. Foliage objects (plants and trees)
. Railing objects
. Stair objects (straight, L and U)
. File Link
. Substitute modifier
. XML material import/export
. Luminaires
. Daylight system (with certain limitations)
. Lighting analysis export
. Camera 2-point perspective correction modifier
. Print size wizard
. Network Region Render
. Panorama Exporter
In addition, this tool gives Autodesk VIZ better file compatibility with 3ds max
5. You can open a VIZ 4 file in max. But note that when performing certain
operations, some data can be lost or modified. (See "Opening Scenes in 3ds max
After Being Saved with VIZ" below.)
After you have run this utility, a new drop down will be added to your max menu
bar: "VIZ R4". From this menu, you can access:
. Lighting Analysis
. Print Size Wizard
. Create Camera from View
. Camera Correction modifier
. Assembly Operations
Весит всё это добро всего 1.63Mb
. Railing objects
. File Link
. Luminaires
. Print size wizard
. Panorama Exporter
. Lighting Analysis
. Print Size Wizard
