Папка должна называться "icons".
Кроме того мона засовать их в другие папки, определяя переменные окружения. Короче вот:
Icons Search Path
Just as you can create preference files, you can create your own icons. The description of the
actual icons can be found in “Using the Alternative Icons” on page 645. Icons can be found in
one of three locations:
- <ShakeDir>/Contents/Resources/icons (<ShakeDir>/icons on non MacOS)–a
directory, not to be confused with the important icons.pak file)
- <UserDirectory>/icons (see above)
- In any directory pointed to by $NR_ICON_PATH, set the same way $NR_INCLUDE_PATH
is set
